Question about Oreck XL Ultra Bagged Upright Vacuum
I have an Oreck XL2 that spits out dirt
When I sweep the Oreck appears to be picking up dirt, but within 2 or 3 minutes it spits the dirt back onto my carpet.I have a new bag in the sweeper and it is correctly installed. My husband removed the tube in back and it was free of fany dirt, . What's wrong? and how do we fix it?
  • vegasluxor2 Sep 05, 2008
    My new Oreck XL,(used about 10 times) has suddenly started to spit out what seems to be the contents of the bag back out onto the floor. This is a new bag, only used once, I removed the suction tube from the back and made sure it was clear, as suggested in directions. It seems to be running backwards, no suction, but adding dirt and dog hair to my floor!!! It is very frustrating. Looking for help
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil M084600 Dynamite
If it is only 2 months old, then it is under warranty, take it in for warranty repair. There may be a circuit breaker on it, usually on the back at the bottom, it there is, push it to see if it has tripped.
Posted on Feb 28, 2008
Agent Don
  • 310 Answers
SOURCE: wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Wiring diagram Oreck XL2
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 09, 2008
  • 430 Answers
SOURCE: vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Posted on Sep 11, 2009
#1 Taper
  • 1040 Answers
SOURCE: our oreck upright sweeper is so hard to push on
Flip the head over and clean the metal pieces on either side if the head. When they get dirty, the tend to stick to the floor.
Jim
Posted on Sep 09, 2010
  • 377 Answers
SOURCE: Oreck xl commercial spits out dust on bare floor
It might be that the beater brush is spinning when you tip it up to look at it but slight pressure of it contacting the floor is enough to stop it. If it were my machine I would remove the beater brush and clean it as best I could, paying particular attention to the end pieces on the brush that hold it in place. A little WD40 between the end pieces and some twisting to be sure it worked in well. I would then reassemble with a new belt being sure it is on correctly so it turns the brush in the proper direction.
That is about the least expensive thing(s) you can do at this point before going further. I have one more potential cause, but it is best to check these first.
Please let me know how you make out.
Posted on Oct 06, 2010
What's your problem? Oreck XL Power Team Lightweight Vacuum not picking up dirt
i have just purchased a oreck xl how do i move the handle so i can hoover
the floor
Oct 27, 2012 | Vacuums
Oreck XL2 does not start.
There could be a problem with the cord. I suggest taking it to a local vacuum shop to have it inspected as that could be the problem
Apr 13, 2010 | Oreck XL2000 Bagged Upright Vacuum
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
My son used it to vacuum up needles from Xmas tree. It is now spitting out dust and not picking up. I changed the bag but does not help
I could not find the manual for the vacuum. I went to the Oreck site and found an online manual for my machine. I was able to take the hose apart and clean out the blockage. Also when I turned the base upside down and rotated the roller, I was able to clean that out too.
Jan 09, 2010 | Oreck XL2000 Bagged Upright Vacuum
Oreck won't pick up dirt.
Check the roller brush, dust channel and then the back spine tubes - two parts which also holds the cloth bag - which holds it at the bottom via a spring. Unhook this, and prise up the rubber rings that hide the push in locks. Push the locks in and the spines should separate.You may need to undo the power cord since it comes out the top near the handle at the bottom. Check both spines and remove clogs with a thin round stick. Put everything back together slowly and switch on.
Jan 12, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Not picking up dirt.
There is a Clog in the machine...
Somewhere between the motor and the bag.
When you use the machine, the dirt picked up by the roller has no place to go but backwards.
You will need to disassemble it and look for the clog.
Nov 22, 2008 | Oreck XL2200 Bagged Upright Vacuum
Go Ahead. Use Us.
Jun 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Wiring
Here are the 4 different wiring for new Oreck motors.
Apr 04, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Feb 25, 2008 | Dirt Devil M084600 Dynamite Bagless...
Oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
Dec 28, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
218 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
