Question about Intertherm Heating & Cooling
How much coolant does a central heat and air unit take, what is the capacity of coolant will it hold?
  • 518 Answers
SOURCE: central heat and air
Without knowing more information:
1. The evaporator coil could be frozen blocking air flow.
2. Dirty air filters will block air flow.
3. If it has a 2 or 3 speed motor, the highest speed should be used by the AC setting. It could be a wiring issue here. You
didn't state if this is a new problem or has it always been this way.
4. If it's a belt driven blower, the belt could be slipping.
5. If its belt driven, you might have an adustable pully on the motor, if so it needs to be screwed in as far as possible for max speed.
I had the same issue years ago. It was like that from the day I bought the house. Mine is belt driven, so I simply bought a larger pully for the motor, thus making the squirl cage spin faster, and I get plenty of air flow now.
That's about all I got for Ya...
Geno
Posted on Aug 02, 2008
  • 8 Answers
SOURCE: no heat coming from central air unit when heat is turned on.
check t stat make sure its set up for you system some stats have to be set up for a heatpump or iits gas or electric heat
Posted on Mar 13, 2009
james3751
  • 614 Answers
SOURCE: how do i put freon in my central heat and air my
This job is best done by service tech. You have to know what your doing to be able to charge a system. Plus you have to have EPA card to handle Refrigerant. You need to call service tech. Remember if you have to put gas in there isa leak. Make sure they look for one if you ahve it recharged. A unit can run forever on the same gas. Cost of chargeing an AC can very from 100 to 300 dollars. My suggestion is to ask for a free estimate. So you know up front what it will cost. Rus
Posted on Jun 21, 2009
luker711
  • 91 Answers
SOURCE: no air flow from duct on forced air unit
If there is no air coming through all of ducts, there are several things to consider. If you turn your thermostat to fan on, does air come out? If so you may have a switching|thermostat problem. May need to change out, not really hard you just have to turn off electric mark wires as you remove and turn back on. If nothing changed, make sure the circuit breaker has tripped, sometimes its hard to tell so flip it all the way off then back on. Now try to turn on again. If it comes on you need to find out why it's tripping the breaker, merely resetting it can pose a danger for the future. Professionally servicing the unit is important to the longevity of the unit. Now if you find out that unit is coming on but no air is coming out, it could well be that a duct has blown free and is spilling into attic or crawl space. Sometimes the unit forms an ice block in the evaporative area of the unit. In this case it would need quite some time off to thaw. Also the fan motor may be burned out. In that case you would hear part of the unit working with no output. These are a few of the most common problems with this condition.Most of which needs to be addressed by a Tech
Posted on Jul 15, 2009
koolbreezes
  • 540 Answers
SOURCE: my Amana (distinctions) central heat and air unit -loud noise
If this s an Oklahoma Tulsa area call. KOOL BREEZES 918 6878813 for a diagnostic check.
Posted on Dec 06, 2009
The A/c and heating unit does not cut on anymore. What could the problem be?
Are you sure you have power? Is it 220? if so double check Circut breaker. If it's popped and pops again when you reset, unplug the unit. Try to reset again, If it pops again when you reset, you have major electrical problem call electrician. If it holds, then you have a major appliance problem that is causing the unit to "pop" the circut breaker. If it's a central unit similar diagnostics, but you can't unplug it. So call your Heating service people. It may just be your thermostat if central system, or more.if the Circut Breaker pops.
Mar 06, 2015 | Heating & Cooling
My corona air conditioner inverter does not produce hot air
these are all in one units, some of them are made like smaller central units and some of these are separate ac and heat units. the heat in the separate ones is run off of a heat strip in the unit it's self the ones that are made like a central unit reverse the flow of the freon in the system to draw the heat from outside. this is not something you can repair very easily yourself. most places require because of the freon that you have a certified HVAC technician to work on them.
Feb 22, 2013 | Heating & Cooling
I have a Goodman heat pump. With the hot weather that has arrived, the air conditioner does not seem to be pumping cold air. do you think maybe that I`m missing coolant.
Hello
Have you checked filters that they all clean, including the out side condenser unite if yes, then it is posable that the machine is short of gas or that the compressor has lost its capacity to pump.
Thanks
Jun 07, 2011 | Heating & Cooling
Haier HR30C1VAR central air unit is not blowing at full capacity the unit is full of freon
clean the coils, with cleaner or a garden hose, disconnect power first remove top and spray from the inside out, not to hard as it will bend the fins closed, you will see dirt come out and pray until it is clean. Good Luck Tim
May 29, 2011 | Haier HC48C1VAR Central Air Conditioner
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
No heat coming from central air unit when heat is turned on.
Feb 25, 2009 | Heating & Cooling
Heat coils in central air conditioning unit look fine under examination, checked with an ohmmeter both coils showed continuity. Power at both coils indicated 110 volts. Unit fan runs fine but there is no...
Are you getting 120 vac or 220 vac at the unit? Check the voltage at the first terminals inside the unit as well as the breaker. You should have 220 vac at the elements and you are dropping a leg some where.
Jan 17, 2009 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
