Question about Acer Aspire 3690-2196 Notebook
Blank screen when i turn on my laptop, the sreen turns blank white but i couod see a few lines across the screen
  • tsumien Aug 11, 2008
    i have an acer aspire 3690 series and when I boot it up the screen is black and the processor is working normally. What could be the problem to havce my laptop boot?
  • 132 Answers
Can you obtain a linux dsl stick / cd - This will help bypass your HD
Do you have floppy drive - if so..can you create a DOS boot disk
try and boot from another media - this will rule out Hard drive / os failure, and focus on the laptop itself.
If this fails - it would appear to be the video driver... let me know from here on..
Posted on Aug 15, 2008
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
Toshiba M300 screen turns white blank.
White screen means that your lamp (back light) is working absolutely fine, but you could have a loose connection for the data ribbon cable, which sends the images to the monitor.
Carefully open laptop to reach its lcd, there must be ribbon cable which looks like this: mrc-0069.gif
It is very sensitive so be very careful with that, very gently remove this from the chip and reconnect it.
Hope this helps, Please feel free to ask me any further.
Apr 10, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
my acer aspire 9300-5349 orbi cam show black screen, how can i fix it..
Nov 10, 2009 | Toshiba Satellite A135-S4527 Notebook
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (
Good luck.
Jun 12, 2009 | Computers & Internet
White line across my laptop screen vertical
Do a hard reset to the system take the battery out and unplug the power cable, make sure to unplug the acadapter from the system so there should be no power on the system, after that you have to keep the power botton pressed on the laptop for 50 seconds and then release it. connect the battery only and turn on the laptop and go to the bios screen. if the line is present in the bios too than its a pixcel problem which cannot be repaired if under warranty get the screen replaced in case its on the windows screen then you have to reload the video driver.
May 05, 2009 | Toshiba Satellite A135-S4467 Notebook
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Acer Aspire 3690-2196 Notebook Logo
3,222 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
