Question about Dell F3534 Touchpad
How do I get the touchpad to activate the scroll bar without having to click to make it move up and down
  • 204 Answers
Hi there!
Try to reinstall the driver for your touchpad.
Hope this helps!
Posted on Apr 10, 2011
Scroll bar on my touchpad/mousepad not working??
Go to Control Panel > Hardware and Sound > Devices and Printers.
Then, right click on the laptop and select mouse settings. Click on touchpad and go to Gestures. Finally, check that scrolling is activated.
Feb 22, 2015 | Gateway NV53A75u 15.6 Laptop X3 2.1GHz 4GB...
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
Touchpad must be continually tapped to make scroll bar scroll up or down
Different laptop uses different type of touch pads. If your's an old laptop, that may not have a scroll function by simply sliding your finger through the right edge(top to bottom and vise versa) to scroll to a desired level. A new laptop has all these functions. Go to the control panel click on classic view in the left pane in case of xp and vista. Then you can see the mouse icon.click on it and select the device setting tab. then click on setting and a new window will open.There click on scrolling and click on one finger scrolling you can see the scrolling properties. tick mark the vertical and horizontal scrolling boxes. click apply then ok and close all the way. Thats it All done. Hope it helps
Dec 02, 2012 | Computers & Internet
Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
Jan 24, 2010 | Toshiba Computers & Internet
The roller bar area is not working
It sounds like the touchpad needs replacing. Contact me if you can't get it repaired locally.
Jan 09, 2010 | HP Compaq 236076-001 Touchpad
Scroll on my touchpad doesnt work
You need to download your touchpad driver made for your XPS off the dell website. When windows installs, or when you buy a laptop, it doesn't come with the latest drivers.
Nov 01, 2009 | Dell XPS M1530 Laptop
Scroll Function Doesn't Work
Scrolling is integrated into the operating system. Try a restore point to a time you recall it working properly. If this doesn't work try a repair from your recovery disc or an operating system repair with your op system disc.
Jun 13, 2008 | Lenovo ThinkPad T61 Notebook
I have lost the ability to scroll using the right vertical edge of the touch pad. Otherwise the pad works fine but it is annoying not being able to scroll any more without moving the cursor to the 'scroll...
The option to enable or disable the scrolling option for the notebook touchpad is generally available by going to the Control Panel, then selecting Mouse. Within that area, go to Device Settings, select the touchpad from the list of available devices, then click Settings. There should be an option for "virtual scrolling" - click on it, and you should be given the options to turn on or off both horizontal and vertical scrolling for the touchpad control.
May 06, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
