Question about Whirlpool Dryers
Our Whirlpool Accudry gas dryer model # LGQ8858JQ2 Serial# MLJ504704 will not heat up. Ignitor looks good, not cracked and replaced the sensor a year ago. Trouble igniting..will not heat up. Is there any way to test the sensor to see if it is bad?
catriver
  • 878 Answers
SOURCE: Gas dryer not heating up
Flash, did you check the thermal fuse in the back? On a gas dryer the drum will still turn if it's blown. check out the picture and post back.
Posted on Mar 29, 2007
  • 1028 Answers
SOURCE: Whirlpool Frontload Gas Dryer
suggest change both soleinoid coils can sometimes cna be very intermittant
Posted on Apr 27, 2008
  • 14 Answers
SOURCE: no heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Posted on Jul 25, 2008
  • 1028 Answers
SOURCE: gas dryer intermittently heats.
most likely solenoids after a few firings they tend to open up and not work again until after cool down replace both they usually come in a kit
Posted on Sep 14, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: How do I open up my Whirlpool dryer(no kickplate) to test ignitor
You can to the ignitor from the back panel. Remove the back panel screws and away you go. Thank you for using FIXYA.COM please rate
Posted on Feb 14, 2009
I have a Whirlpool AccuDry Dry (Model LGQ8858JQ2). It will start fine, but will stop shortly into the dry cycle and beep three times. The drum turns and I checked the belt. The timer continues..but at
I think that it's a door switch error.
Open the door and locate the door switch. Exercise the switch with your finger about twenty times then try the dryer again. You may have to replace the door switch.
Check youtube for help videos on replacing the door switch.
Nov 05, 2014 | Whirlpool Dryers
I have a whirlpool LGR8648pwo. Runs not heat and timer doesnt move. I found a 4 prong sensor in the back of the unit. 2 prongs have continuity and the other 2 dont. Is that bad.
If no heat at all i suspect this part HERE. This is the fuse. It kills power to the gas assembly if junk gets into the filter housing and cause an overheat condition. On electric models this same fuse kills the whole dryer. On gas models it just kills the gas. If that is good the next thing to check is the flame detection sensor mounted out side of the burner chamber. It's job is to power up the ignitor. If it is open no power can get to the ignitor. If it is good then the next thing to check is the ignitor. If the ignitor is good AND you are getting power from that control klixon you mentioned with the 4 wires on it AND you can get a little heat at first but then none at all them coils need to be replaced. Here is my home video:
Dec 09, 2012 | Whirlpool LGR8648 Gas Dryer
Whirlpool Gas Accudry dryer has no heat...everything else seems fine.?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[
Aug 11, 2011 | Dryers
Whirlpool AccuDry Ultimate Care II Dryer will heat up
heatman101
Jul 17, 2011 | Dryers
Dryer not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 04, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Whirlpool gas dryer doesn't heat - model lgr4434aqo. We replaced the operating thermostat, but still no glow from the ignitor or sound from the gas valave assy.
The ignitor has gone bad...you need to replace the ignitor...they crack and then they will not glow...look for a faint white line across the surface..that is where the crack is.
Here is a tip that I wrote about this problem..
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Dryers
Whirlpool gas dryer no heat
The problem is probably with the ignitor...these are very fragile and burn out easily or crack...
Replace it and you will be working again...
Here is a tip on how to fins the part online...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 04, 2010 | Whirlpool LGR5636L Gas Dryer
Not heating up Gas Dryer
Modern gas dryers do not have a pilot light. They have an electronic ignitor (glow or spark). A glow ignitor turns on several seconds before the gas turns on and should get orange hot. A spark ignitor should make a clicking or buzzing noise.
Most likely the ignitor is bad but you can check it fairly easily to make certain. The best instructions I have found are at
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
If it is the ignitor it can be replaced with a few hand tools. Remove the bad ignitor. Write down the make, model, and serial # of your dryer. Call your local appliance parts store to see if they have one it stock before driving over there.
Dec 22, 2009 | Whirlpool Dryers
My dryr tumbles but does not dry
Gas dryer? First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Electric dryer? Temperature sensor has failed or heating element has burned out.
May 30, 2009 | Whirlpool Dryers
Samsung dryer smells like gas
Replace the operator coils. They are intermittant. Typical operator coils look like this:
Nov 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
127 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
