Some routers have passwords printed on the bottom. Most routers use "admin" as username, and then either default password or unique password. In any case, read the user manual, you should find it there. Download Free Manuals
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.if there is a small hole in the front or back of the router push a hair pin in to reset to factory settingsHope this helpsdon't forget to vote
Most of the NETGEAR devices, except ReadyNAS products and Fully
Managed switches, have the following default username and password:
Username = admin
Password = password
For older devices, password = 1234
If you have changed the default password and have forgotten it,
you will need to reset the NETGEAR device to factory default settings in
order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
Most of the NETGEAR devices such as routers and smart switches.
you would need to reset to factory default setting for the exact problem you are having -- forgetting the password. so your question is "YES".
The Restore Default Settings feature will erase any previously saved
settings and restore all of the settings to the default.
From the XMB™ home menu, go to (Settings) > (System Settings) > [Restore Default
Settings].
The message "Do you want to restore the default settings?" should
appear. Select "Yes" and press the button.
You will then see a message, "All settings will be returned to
default settings. Are you sure you want to continue?" Select "Yes" and
press the button.
All settings are now restored and the system password is reset to
"0000".
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Restore Factory Default Settings
When you restore factory default settings to the base station, you clear your Internet connection settings and any
special base station configurations that you have established. After the restore is complete, you will need to
reconfigure your base station settings or restore these settings from a backup file.
You should restore the original factory default settings only under the following circumstances:
O You are experiencing serious problems with your base station, and resetting the base station does not fix
the problem.
O You cannot remember your base station password. In this situation, you must restore the factory default settings
by using the Restore button on the base station, and then use the default password admin to log on to the Base
Station Management Tool.
To restore factory default settings
1. Open the Base Station Management Tool, and then click Management.
2. On the Management menu, click Back Up and Restore Settings.
3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory
default settings are being restored to the base station, the Power light on the base station turns orange. When
the light is solid green, the settings have been restored.
If you want to open the Base Station Management Tool after the settings have been restored, type admin as the
password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the
Power light on the base station is solid green.
After you restore the factory default settings to the base station, you should navigate to each page of the Base
Station Management Tool and reestablish the network settings you want, or restore the base station settings by
using a backup file. For information about creating a backup file of your settings, see the following section.
Be sure to establish your unique base station password as soon as possible after restoring the factory default
settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station
Password.”
please rate this answer, thanks
The default username and password for the Netgear DG834G router is:
username: admin password: password
If that does not work (i.e., the default password has been changed), then the only way for you to log into the router is to restore the router back to its default factory settings. Then you will be able to use the default username and password above.
To restore the router's factory default settings, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot.
