Question about Garden
I would like to have the instructions to install my kobalt hanging storage unit Model #: 45577PKDLG
I need the spool cover for my Kobalt trimmer
The Kobalt brand is sold at Lowes. Although there are several other companies' trimmer covers sold there, I have no idea if any could substitute. Here is the phone number for Kobalt Tools, the manufacturer. Perhaps they can assist.
  • 1-888-3KOBALT
  • (1-888-356-2258)
  • Monday - Friday
  • 8:00AM - 5:00PM EST
KOBALT
Jun 08, 2017 | Garden
My small rachet has packed it in have been told to contact kobalt tools to get replacement where do I contact them
Kobalt tools is a Lowes home improvement brand. Contact your local Lowes Home Improvement Center.
Apr 23, 2016 | Cars & Trucks
How do I set my Cobalt LDM-35? Error 208. Won't measure
Kobalt Ldm-35 - Power Tools Best Sellers Reviews
kobalt-tools.top-100-bestsellers.com/kobalt-ldm-35.html
Best Kobalt Ldm-35, Kobalt Tools for sale - Bestsellers Catalog Online helps ... LDM 35 Error 208; Kobalt Laser Distance Measurer Review; Kobalt LDM 35 ..
Sep 08, 2015 | Cars & Trucks
How to operate kobalt LDM35 laser. Distance measure
Try Googling (kobalt)(LDM35)(manual) without parens to get instructions.
Oct 26, 2013 | Measuring Tools & Sensors
Need kobalt work bench assembly instructions
I have been repairing compressors major brand Rol Air, Dewalt, Porter Cable, Jair, Jenny, Emglo, etc. and find, even with major brands,very limited information on assembly instructions. I havent seen any material on Kobalt, however find that their compressors are very much like the oil-less from cambell hausfeld, dewalt and porter cable. Parts are available on the net. The major problem that I see is that there is no easy / reliable way to install the drive belt. Without proper procedure or tools, the belt will tear. For the most part, you are on your own to experiment on repairing them. You can re-post a specific question on the Kobalt and I will try to answer. Good luck.
Nov 10, 2012 | Air Tools & Compressors
I recently acquired an ibm wheelwriter 6 type 674X typewriter. I have looked on line for an instruction manual. I can't find one for this model.i am wanting to type labels or phrases repeatedly and am not...
To record you hold down"store" and hit "1" that opens the storage unit. Type what you want to keep. when finished press "store" again. that closes that storage unit. When you want to play that , hold "play" and tap "1" that storage unit will play out. You can repeat this in storage areas "1" to "99" until the memory is full. To delete the storage unit, hold "delete" and hit a paticular storage area, such as "1" all will be deleted.
Jun 21, 2010 | IBM Wheelwriter 6 Typewriter
I need a kobalt hvlp spray gun manual where can i get one?
Go back to where you bought it and have them photocopy the book from another unit. Good luck!
Jun 19, 2010 | HVLP 10 Piece Hvlp Paint Spray Gun Set
On my kobalt digital air compressor i have 150
This was a poor design for kobalt with digital readouts.. The compressor waqs made by several comanies including campbell hausfield and porter cable, But some were imported.
There under the controls is a switch that cuts out the motor, It looks like an oil pressure switch on older cars. There is also a manifold tree that holds the guages and the regulator. There will also be a circuit board that holds the electronics for the regulator control.
Remember you have to set a value to bring up the pressure and the board senses the tank pressure and "Bleeds" off via a solenoid to hold the pressure. The ticking sound you hear is the solenoid, ITs not repair/replacable.. its part of the controls.
If the unit is under warranty you might eant to ask lowes who is their off site repair center, or ask is it available to be exchanged.
Personally, and professionally.. this model is oiless, so it has a shorter life as to being reliable compared to oil lubrication. For the extra bucks you will come out with a more reliable and easier to service model.
Nov 18, 2009 | Air Tools & Compressors
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
