GE5900 dryer-motor runs,no heat
voltage good,wires good,element continuity good, short-wired all thermo switches and motor switch.Still no heat.Could it be the timer?
hello there: Testing with an ohm meter checking on a
dryer.... These are the places that pass voltage to the heater
elements on an electric dryer. In order to check a dryer for no heat, here is a list of
places to check. Remember to always unplug the appliance
before starting testing with an ohm meter. Always remove wires from the part you are
testing with an ohm meter ( write down what goes where first before removing any
wires ). Meter
testing and usage tips. 1. Power supply-check power
supply at terminal block where cord enters the dryer. Should read 240V. If you read
240V here,
tested with a volt meter, unplug dryer and test components with ohm
meter. 2. Thermostats-Cycle and
safety thermostats-read them with an ohm meter. Should show
continuity . How common thermostats work. 3.Timer-The timer has a set
of contacts that pass voltage to the heaters. If you can not determine by wiring picture
what they are, check across the two terminals with the largest wires on them. The heater
wires are almost twice as large as the others. You should read continuity with timer in heat mode. 4. Thermal fuses-In recent
years the makers of dryers are using thermal fuses to let you know something is wrong with
your dryer. They are generally non resetting and have to be replaced. The thermal fuses
are located on the heater element housing and should read
continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air
flow problems or a grounded
heating element. 5. Selector Switches-Read the
wiring picture and determine which switch is closed. You should read continuity across closed switches. 6. Safety Switch on Motor-There
is a safety switch on motor to insure that heaters can not come on unless motor is
running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check
with an ohm meter, remove the two large wires on motor switch and make them electrically
safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals
on the motor switch you removed the heavy wires from. If it is ok you should read
continuity. Remember that the smaller wires in a
dryer carry the 120V and the large wires carry 240V. There is no voltage on these two
terminals with wires removed. It is ok to test with ohm meter. 7. Heat elements-Test heater
element with an ohm meter. You will read continuity
across a good element 8-12 OHMS
Hello there here is a list of things to check Testing with an ohm meter checking on a
wires ). Meter
240V here,
across a good element ( 8-12 ohms is an average element ). But darn it, I
don't have a Ohm Meter.... To check the thermal fuse - You can bypass the
thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out - You can bypass
the thermal cut-out (just connect the 2 wires together) for testing purposes
only. To check the thermostats for continuity - -
You can bypass the thermostat (just connect the 2 wires together) for testing
purposes only. To check the Element: Try removing element and
physically looking at the element wire for a break in the wire.
The motor has to be running for voltage to exit the motor going to the heater. With the back off the dryer and the motor running you should read 220 volts at the heater if all safetys and thermostats are good. There is a thermal cut out relay on the heat canister. It must read continuity also. Remember you must remove at least one wire from each component being tested to get a true open or closed reading. If a wire is left connected you get a false reading. The heating element could be broken and part of the heater wire touching the canister. This would cause a continuity reading and still no heat. Finally, yes,the centrifugal switch in the motor could be bad and not sending power to the heater on the red wire.
I think your heating coil may have broken loose or sagged down so that it may be shorting itself against the shroud. The thermal fuse would not allow the dryer to heat at all, and a hi limit error would cause the thermal fuse to blow.
Running is good. That means lots of stuff is working. On the motor is a switch that turns the heat on once the motor gets up to speed. The other wires on the motor are start and power for run. Check your heater elements for continuity. Running usually means the door switch is ok, timer ok. Check around for fuses, burnt wires, loose wires. Check the heat sensors for continuity. They should conduct electricity untit they get hot.
There are several things to check...1st did he check the voltage comming into the dryer....if it is 220 volts, then you have one wire that runs the heating element and the other wire runs the motor there should be a black wire (power) and red wire(power)also a white wir(this is the common) and if your dryer has a four(4) prong wire pig tale(or power cord) then there will be a red wire black wire...(the power wires) a white wire..the common and a green wire...externial ground. after u check for power then check the door switch for continuity if the door switch has that, then check for the fuse if applicaple... if all these are good the you may have motor problems, nbut that will give you a start.
Q - My electric dryer runs but will not heat, what could stop my dryer from heating? A - Things that could stop a electric dryer from heating: - house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug. A ohm meter test for these parts is here. Q - My gas dryer will not heat, what could stop my dryer from heating? A - Things that could stop a gas dryer from heating: - glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor. A page for checking gas dryers is here. Meter testing and usage tips. 1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter. 2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work. 3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode. 4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element. 5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches. 6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter. 7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ). But darn it, I don't have a Ohm Meter.... To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only. To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only. To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Check for 220 volts incoming at the terminal block where your cord connects.
Make certain the dryer wiring is good there also.
Check the heating element to a ground on the dryer.
Check the continuity tthrough the start switch on the motor.
for the heater wire connection.
possible voltage issue be sure you have steady 240 at 2 outside screws on ac connection next ck timer quick ck unplug dryer remove console cover short large red and black wires together plug back in and turn on ..possible motor switch ..contacts in motor switch close as motor runs supplying one side of element with other 110 volts
NO HEAT, CHECK THE FOLLOWING:
1. CHECK SETTINGS OF THE SELECTOR SWITCH. MAKE SURE A HEAT SETTING HAS BEEN SELECTED.
2. IF IT IS AN ELECTRIC DRYER, CHECK FOR 240VOLTS AT THE OUTLET.
3. CHECK THE HEATING ELEMENT FOR 240 VOLTS AT THE TERMINALS OF THE ELEMENT WHILE THE DRYER IS RUNNING. IF NO 240 VOLTS, TRACE WIRING BACK TO OTHER COMPONENTS OF THE HEAT CIRCUIT. WHEN YOU FIND 240 VOLTS ACROSS THAT COMPONENT, THAT IS THE BAD ITEM.
4. CHECK FOR BURNT WIRES IN THE HEAT CIRCUIT. (HEATER, THERMOSTAT, HIGH LIMIT THERMO, MOTOR CENTRIFUGAL SWITCH, TIMER, THERMAL FUSE).
