Question about Garden
How the carburetor springs go on my Weed Eater 20'' 300 Series Side Discharge Push Mower Model # 961140014
rockitman187
  • 2559 Answers
SOURCE: How to change the spring
Which spring are you referring to?
And this is the gas edger,Correct?
Posted on Aug 04, 2009
SOURCE: carburetor adjustment weed eater fl sst 25,will
My machine didn't run idle either. Took carburator apart of the Sst 25. Cleaned it with gasoline and a brush. But no luck. Figured it must be the nozzle of the idle. There are two more or less hidden black adjustment screws for the nozzles (idle and gas). I used a plastic tube from a ballpoint to take screw out, ran some air through it, reassembled it and now the machine runs smooth again...
Posted on May 21, 2009
  • 8 Answers
SOURCE: Mower starts up great and then dies
If it's a briggs engine, sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure ur float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish bt reattaching the air filter support bracket makinf sure the gasket between the carb and the bracket isn't damaged.
Posted on May 25, 2009
joe7379
  • 93 Answers
SOURCE: My weed eater will not start
Sounds like the carb or gasket around the carb is leaking allowing the pressure to blow by when you press the primer bulb. If its not air tight it will not pop back out. Check your carb and surrounding gaskets and check for a leak.
joe
Posted on Jun 28, 2009
pumpkinman
  • 1147 Answers
SOURCE: How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Posted on Jul 25, 2009
I need to get weed eater gas out of my lawn mower then fix what damage its caused... any ideas on how to do this?
So you put 2 cycle gas in a 4 cycle engine... here's what u do. First obviously is to flush the fuel system.... by the way, the 2 cycle mix won't kill your mowers engine, it will affect the carburetor mostly... that's gonna be your main point of focus. Remive it, and take it apart and clean it well, use gum out or any carburetor spray and use it generously. If you have an air compressorthis is a plus.
If you can find it, get some LAWN MOWER TUNE UP... made by the same people who make PB BLASTER... stuff is great for cleaning cyclinders and preventing rings from sticking etc.
When you eventually start your mower up again, it's gonna smoke a bit, but will eventually dissipate.
Oct 13, 2015 | Garden
How can I start featherlite weedeater with poulan carburetor sst 25?
Your Poulan should have a green button on the side of it. Push and hold it. While most models have a green button, your may not. In that case, obtain the model number off the weedeater, go to Poulan.com/customer service and download the manual for your machine
Sep 01, 2014 | Poulan Recertified - Weed Eater...
HOW TO ADJUST DRIVE CHAIN ON WEED EATER ONE
There is a tension adjustment on the body.. flip your mower over and you can see it better.. do not over-tighten it though because it needs slack to let the 1-2-3 to change on the fly.
Aug 18, 2014 | Weed Eater WE-ONE 26-Inch 190cc Briggs &...
I have a Weed Eater Electrolux Model 961340001 02 push mower with a Briggs and Stratton Q4.75 engine. I'm have trouble finding the model # on it.
Look on the engine blower cover should be on the side. It will say model and type and code. Go to sears direct and put the model and code in and should bring you up to the owners manual.
Jan 23, 2013 | Garden
Weed eater one friction disc problem
HOW REPEAR THE FICTION HOB WEED EATER TRACTORS
Aug 22, 2012 | Garden
How do you check the oil in a Weed-Eater-500-Series Side Discharge Mower, Model 10854261. It has a basic Briggs Stratton engine. I have a lost the manual and cannot figure it out!! HELP!!!!
most mowers have a dip stick like a car and the oil should be changed often and acting as if it wants to stall try fresh fuel gas is only good for 30 days in small engines
Mar 27, 2012 | Briggs & Stratton Garden
I have weed eater/poulan 22" push lawn mower. It
Hi goldengear...
Make sure you have installed the blade on the right way, if it is installed upside down then it will "beat" the grass instead of cutting it and make a terrible cut, also make sure the blade is good and sharp.
The rough running may be due to trash in your carburetor, I would advise to clean your carburetor and also check you fuel tank for trash, water,etc. if there is any trash,water,etc in there then you need to also clean the fuel tank.
Do one more thing and check/clean/replace your fuel filter if you have one.
Please take time to rate me
Aug 18, 2011 | Poulan "Poulan" Push Mower
Weed eater 961380017 where is oil drain plug located?
On the Weed Eater 961380017 it uses a Rato engine and the mower is made by Husqvarna, it is the same as their U.S. model 5521P. To drain the oil you have to first remove the dip stick and then tilt the mower over to drain the oil out into a pan.
Aug 04, 2011 | Garden
Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Aug 09, 2009 | Garden
Weed eater featherlite primer bulb won't fill with gas. it does not appear to be broken and fuel line is clear and filter is new. any ideas?
Hello
From your Description and Depending on the OEM (Zama or Walbro) of the Carburetor it Sounds like a Bad Fuel Filter or the Primer Check Valve has Stuck and the Carburetor Requires Soaking and Cleaning.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://www.poulanpro.com/poulanpro/indexAction.do?id=default and Select Order Parts and Accessories. On this Page Select Illustrated Parts List from the Menu on the Left. Now Select the Manufacturer (Poulan/Weed Eater) and Enter the Model Numbers in the Boxes at the Lower Left of the Page.
I Require the OEM (Walbro, Zama, ect) and the Model Numbers Off the Carburetor. With these I can Locate a Breakdown of the Carburetor and Better Assist you.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
332 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
