Question about OKI MICROLINE 320 Turbo Matrix Printer
Printer prints in a diagonal line not straight
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Phaser 7300 Printing Diagonal Lines
Have you perform print test page? if yes does it exhibit the same symptom?
I suggest you reset the printer as below before perform the print test page.
Reset as below
1. remove any power supply from the printer including the power cord from the main socket.
2. Leave it for about 35 minutes
3. Plug in the power cord again and turn on.
Apr 23, 2008 | Xerox Phaser 7300DN Laser Printer
Why do I have white / faded print when printing black? It also has problems printing straight lines - sometimes jagged sometimes just faded.
I do not know for sure but it sounds like the paper is not griped properly, this would cause the jagged lines. I would try another ink cart when the loose paper problem is resolved. I hope this helps.
Jul 23, 2014 | United Stationers HP Officejet Pro 8600dn...
Diagonal lines on HP CP1215 printer
hi your printer lsu unit problem or engine controle contact complaint please check the two parts
Jul 03, 2014 | HP LaserJet CP1215 Color Printer
Hi, When printing photos, my photos have horizontal light coloured lines across them. When I print the nozzle check pattern all colours match the guide with the exception of the light magenta....
Epsons are notorious for this sort of problem, especially in used infrequently as ink residue dries on the print head; try using a cleaning cartridge, or swab around relevant print head with cotton bud and ethanol/isopropyl alcohol. Here are examples of cleaning carts, there are others http://www.internet-ink.co.uk/epson-cleaning-cartridges/ http://www.icompinkcartridges.co.uk/epson-r200-r300-r220-r320-r340-cleaning-kit.html
Jan 03, 2011 | Epson Stylus Photo R200 InkJet Printer
Cannot print graphics accurately. Barcode and text
Problem with your software.
Tec do have instructions for printing diagonals.
Your software must be sending graphics with grey pixels.
Nov 03, 2010 | Toshiba TEC B-472 Thermal Label Printer
Epson Stylus T10: Horizontal bands when printing cyan
With I could post a solutions but I have the same problem! Cyan has horizontal gaps, rest of the colors seem to be ok. I've realigned and cleaned the heads many times.
Mar 17, 2009 | Office Equipment & Supplies
White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Nov 10, 2007 | Lexmark X5470 All-In-One InkJet Printer
Problem while printing rectangular boxes
check your printing program. are you using a mac or apple program? like quark? check setup, maybe there's something like reverse printing option or transparent printing.
Sep 11, 2007 | HP DesignJet 500ps (42 in.) InkJet Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
167 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
