Question about Gateway Computers & Internet
I have a Gateway Model 831GM. It will not start. I replaced the power source based upon Gateways suggestion and still won't start. Tried bypassing the switch to see if switch was bad, still nothing. Completely dead. No fan, or lights. Suggestions?
    Master:
  • 397 Answers
Sorry to be the bearer of bad news but Gateway machines are fitted with Bestec power supply's (dreadful things) and usually when the power supply goes it takes the mother board with it.
I live in an area prone to electrical storms and I probably get one Gateway machine a week into my workshop with exactly this problem.
Posted on Aug 07, 2008
Need gateway user manual's for ne56r-10u
Is this your laptop model? It doesn't seem right to me, usually Gateways have a model such as M200 etc... have you tried here?
https://support.gateway.com/s/manlib/Notebooks/notebook.shtml
Feb 23, 2014 | Gateway NE56R10u Laptop
Sound driver for gateway 831gm windows-7
If you are having problems with the driver, a standard reinstall should be enough to fix it. Navigate to Start->Device Manager and click on "Sound, Video, and Game Controllers". Right click on your sound device and click "Update Device Drivers".
Apr 16, 2012 | Gateway 831GM PC Desktop
Gateway 831gm - press power on, power is there but will not stay
If the power button is not defective in/out, it means yuo have a defective power supply.
Thanks
Jul 30, 2010 | Gateway Computers & Internet
I am trying to determine what cpu pentel 4 (D) 3.0
Gateway 831GM Pentel 4(D) is for socket 775
Jul 25, 2010 | Gateway 831GM PC Desktop
I have a Gateway 831gm It was working fine until I unplugged it to move into the other room. now it won't start. I can get the fans to start if I hold the button in but the lighted switch and power light...
You power supply is broken. It can happen at the drop of a hat. Plug in your PC model in google and follow it by the words power supply. You should be able to get one for $20 or less.
Sep 22, 2009 | Gateway 831GM PC Desktop
Gateway 831GM Eratic Fan Noise
This can be caused by several things:
1. Bad temp sensor
2. Bad voltage, but that will usually cause the whole system to restart
3. Too low maximum temp setting inside the chassis(setting is in bios), often denote as max case temp.
One way to bypass the problem is rig the fan to a molex adapter with a variable voltage molex to 2/3/4pin fan connector and adjust the speed to the maximum quiet setting.
The 831's did run a bit warm so if the case temp setting is set to low it will fluxuate quite a bit. Try adjusting the max case temp up around 50c just to see if that does it, if it does either use the variable voltage dial solution or add a second case fan that's always on, prefferably a low RPM running direct off molex so it will reduce the average temp and therby the need of the monitored case fan to rev up.
Chris
Armor-IT
Apr 24, 2009 | Gateway 831GM PC Desktop
Gateway 831gm not booting. Fans come on but no boot process.
2 questions:
When you say new motherboard do you mean an actual new motherboard or new to that machine, but came from another used model?
When you say you tested the power supply do you mean with a voltmeter/ammeter or put it in another computer and it worked?
I worked on several gateways with similar problems and it boiled down to motherboard issues.
I tested it by replacing the power supply with a bigger (used) power supply and it worked great (for 1 time) and then put the other power supply back in to confirm my diagnosis and yep it wouldn't boot. The next morning I was going to run some virus/malware cleanup and installed the other (known good) power supply and it would not work. I tried all day to get it to boot and it did about twice in a 4 hour period. When it did run it would run great but any attempt to restart it would cause it to crash. No ryhme or reason, it would not fail the same way more than twice. Sometimes beeps, other times no beeps, sometimes it would start up with no video (could hear the Windows starting sounds) other times it would start up normal. I could let it sit and it would start or I could keep trying in sucession and it would eventually start. Some times the fans would slow down from a roar, sometimes they wouldn't. So with a known good power supply that had 150 more watts than the original I diagnosed it as a failed motherboard. But if you have put in a brand new motherboard then I would replace the power supply, because a bad power supply does not mean no power, just not enough power. Please post back and let us know what you find out.
Mar 31, 2009 | Gateway 831GM PC Desktop
Gateway 831GM Video card
The 831 only supports 2 gigs of ram any more and it wont start. You can probably fit a 9800 in it but would be a very tight fit.
Nov 30, 2008 | Gateway 831GM PC Desktop
Gateway831GM-What memory is suitiable. I now have 4 256's
You need some 184-pin DDR SDRAM memory. Althrought, i think you have 4 slots with 2 Gigs max, so I suggest buying 4x512mb
Aug 14, 2008 | Gateway 831GM PC Desktop
Computers & Internet Logo
218 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
