Question about Andis Health & Beauty
CisfI bought an Andis Pet clipper AGC 2 speed. Have 2 blades - 7FC and 10FC. have lost directions on how to change the blades - can you send me directions so I can print them?
    Problem Solver:
  • 8 Answers
With the clipper running, grasp the blade set by the edges and flip it down away from the clipper on its hinge. Simply slide it forward off the tang and slide another blade while the clipper is running. Snap it up toward the clipper and you're set.
Posted on Apr 10, 2011
The mounting hinge will not raise on my clippers when I push up on the button below the blade
whilst pushing the release button (latch) you must also pull the front of the blade away from the clipper.
Jul 30, 2014 | Andis Agc Single-speed Clipper Lightweight...
Blade not staying on tight
If you can pull the blade away from the clipper without pressing the blade release button then either the hook on the Latch is broken (which will mean all blades have the same problem) or the blade socket on the blade may need adjustment or replacement. Please view the part in question Latch
Mar 12, 2014 | Andis Agc Super 2-speed Clipper...
Single speed
Maintenance must be done and clean the engine
Jan 25, 2014 | Andis Agc Super 2-speed Clipper...
Moser max 45 won't cut
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Sep 15, 2013 | Andis Agc Super 2-speed Clipper...
Andis Clippers not locking
Make sure you are putting the blades on with the clippers running otherwise the blade will not locate correctly. Failing that it could b e a broken 'latch' AGC
May 01, 2013 | Andis Dog Clippers - AGP Super 2-Speed...
Problems Andis AGC 2
Sounds like it's time to replace the clippers with something much better.
Apr 24, 2013 | Andis Agc Super 2-speed Clipper...
Why is clipper over heating
Either your blades need cleaning and oiling or it's possibly a faulty armature without testing the clippers and part mentioned with a multimeter it's hard to say. Armature
Apr 01, 2013 | Andis Agc Super 2-speed Clipper...
My clipper smoked and now it wont run at all
Sounds like your motor went out. You might as well buy new clippers for the price to fix them. One thing that causes that is when you spray your coolant to not hold your clippers blade up. Keep them blade down. The coolant can run into your clippers and burn them up. You only want to use grease inside your clippers.
Jan 21, 2013 | Andis Agc Super 2-speed Clipper...
How do I replace blades
Push the latch at the base of the blade towards the blade, at the same time push the teeth away from the housing. Lift blade off blade hinge.
Dec 08, 2012 | Andis AGC-2 2 Speed Dog Clipper
Andis Super 2 Speed AGC Clippers - The blades get very hot !
Buy some Kool Lube (Oster) or Andis Blade Coolant. Both are aerosols. Your 2-speed runs faster, so your blades heat up quicker. Check them often by touching them to your inner wrist, and spray them when they are hot. A bonus is that the sprays also disinfect! (FYI a hot blade can badly burn a pet, so make sure you keep them cool)
Apr 09, 2009 | Andis 29745 Clipper Headliner Hair Trimmer
Health & Beauty Logo
304 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
