Question about Hitachi 53UDX10B 53" Rear Projection Television
Picture loss picture goes off cross hairs appear
  • Hitachi Master
  • 8,617 Answers
Sounds like the convergence ICs and resistors due to the double image. You need two convergence ICs both STK392-110 ICs and the following six resistors. (2) 3.3 ohms 1watt resistors, (2) 1.8 ohm 1watt resistors. (1) 1.8 ohm 1watt resistors. (1) 3.9 ohm1watt resistor. You can get replacemnet ICs and resistors at the following link and they provide free instalation instructions so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 07, 2008
Can excess hair loss lead to baldness, if so what are the treatments available?
Lack of hair growth with specific pattern and areas are generally called as baldness. Excess hair loss is one reason of baldness although genetic as well as hereditary reasons are the main causes of baldness. Treatments of baldness include natural hair restoration, hair transplantation surgery, hair loss treatments etc. My bother consulted a hair transplant clinic in Toronto where he got quality treatment for baldness.
Aug 22, 2013 | Hairart Health & Beauty
Can I buy hair loss treatments on Amazon?
YES, You can buy hair loss products online but these type of product contains chemicals and other things, which are responsible for hair loss problem.
If you are facing hair loss problem , you should consult with an expert , it is your choice to take treatment or not but consultation is must once to know everything about problem.
PRP Hair Loss Treatment
prp treatment for hair loss-x55w4051btyzha1ewcish1pi-5-0.jpg Mesotherapy & PRP treatment tackles exactly those all problems which results in a stimulation of #natural hair growth and immediate #stopping of hair loss.
Apr 24, 2013 | Health & Beauty
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
When I raise the cross hairs on the scope on the graft the bullet goes down and when i lower the cross hairs the bullet goes up is this correct. When I bought my pursuit boar sight from Basspro I only...
That is right. If you had the rifle held in a vice aimed at a particular point and without moving the rifle you raised the cross hairs you would now be aiming above the point. To get your aim back onto the same spot you would have to loosen the vice and lower the barrel of the rifle. This would mean that the next shot would hit the target lower down. The same is true if you lower the crosshairs which means the bullet would rise.
Likewise moving the crosshairs to the left brings your shot to the right and moving them right brings your shot to the left.
Sep 15, 2010 | Sport & Outdoor - Others
Parallax
What is out of focus? Your cross hairs or your whole picture? The parallax error is when you shift your head left, right, up, etc, the cross hairs stay on target. sometimes it will move with you and you will be off. But it shouldn't effect your site picture. You should still be able to see down range and the cross hairs should be in focus. Your rear most knob on the scope eyepiece will adjust to your vision. Mainly for the cross hairs though. I hope nothing broke loose in there to make it go out all at once. Hope this helps.
Mar 28, 2010 | Barska Optics Barska 10-40x50 Ao Varmint...
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
