Question about Sharp Microwave Ovens
I need a part. Part # NCPL-AO24WRFO - Sharp Microwave Ovens
  • Sharp Master
  • 9,098 Answers
That would have been NCPL-A024WRF0 (zeroes, not ohs) but it has been replaced by part # NCPL-B002MRF0, which we can supply for $5.00 postpaid.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 08, 2008
I need the specs for GE Spacemaker XL JVM1339BW002 and need to know since I am replacing this unit w/another GE what type of venting do I need, and will I need to purchase a new trim kit?
The GE Answer Center can answer those questions. 800.626.2000
Give them your full model number.
I regularly repair these.
Feel free to contact me via my site with your full model number and FCC ID number as shown on the tag in or on the oven for more free help.
Nov 26, 2016 | GE Microwave Ovens
Fuse Specifications
Suresh,
Most of the time you will need either a 15 amp or 20 amp fuse for your microwave. You will want a ceramic fuse and if you still have your old one, the amp rating and all info you need will be stamped on one of the silver collars at each end of the fuse. Hope this helps!
Jul 09, 2015 | Microwave Ovens
Keypad shorted may need service
You'll need to carefully removed the keypad assembly and look for moisture etc.
Nov 29, 2017 | GE JVM1740DM Microwave Oven
KBHC109 magnetron needs replacing
So what is your question... do you need a meg tube, need to know how to replace, you need some one to replace.
Mar 27, 2012 | KitchenAid KBMC140HSS Convection/Microwave...
I have a Sharp 930 Convection Microwave that is no longer rotating. Any help?
This problerm is commonly attributed to a turntable motor that is no longer working. If the model number you posted this question under is correct, the part number for a replacement turntable motor is 46-841666-3. You may also consider replacing the turntable coupler (also called the turntable shaft). The part number is NCPL-A021WRFO. If your existing coupler is still in good shape, there is no need to replace it.
Replacement parts can be purchased on line at searspartsdirect.com. There is a complete list of helpful exploded view parts illustrations to assist you with parts identification/location.
If you need instructions on how to replace a turntable motor, the following link explains:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
If you have any questions, please post back and let me know. I hope this helps you.
Jan 29, 2010 | Sharp R-930AK Convection/Microwave Oven
I need to replace the light bulb under my advantium 120 but my wife threw the lighbulb away I need to find out what size lightbulb I would need
I would think that you can find that info either in the owners manual or right in the area where the light resides. Usually there is a sticker there with the info you need. Best wishes!
Jul 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Sharp microwave...I can't find or identify the part I need
This is the "turntable coupler".
For model number R-1461, that part number is NCPL-B005MRF0 (note that those are zeros, not "ohs")
You can order this from Encompass here or you can call them toll-free at 866-779-5835.
Jun 15, 2009 | Sharp Microwave Ovens
What is needed to install the Sharp R1880LS? Is a bracket needed? Thank you, Jill
If you don't have your installation instructions, you can download them here. You will need the free Adobe Reader to view or print this document.
It will tell you what parts are needed. The best place to order Sharp parts is Tritronics.
Jul 29, 2008 | Sharp Microwave Ovens
Lost middle part of rotating plate
Find your model # on the sticker inside the microwave and go to http://www3.sears.com/ or http://www.appliancepartspros.com/partsearch/.  Should be able to view diagrams and find what you need here.  I could help you look it up but I would need the model # and the parts you need.  Would appreciate a solved rating for the advice unless you have further questions.
Oct 26, 2007 | Danby DMW902 Microwave Oven
Need to operate the microwave at 230 volts
You will need a step-down transformer of the appropriate power (wattage) and the proper adapter plug for the country you'll be in. You need to look on the back of the microwave and see how many watts it CONSUMES, not how many watts of cooking power it produces. Usually the power consumption requirement should be in the ballpark of twice the power output. For a 700W (cooking power) oven, I would suspect it has about a 1400W power consumption requirement, so your step-down transformer must be rated at least 1500W. That may be cutting it close, so for lower heat and longer transformer life, I would choose a 2000 watt model. You need to be sure it comes with an adapter plug that's made for receptacles in the country you'll go to. One site I found has them for about $60. but I would read up on the subject to see if you need one of an EVEN HIGHER rating since microwave ovens do surge when they start cooking. You may need to use one rated at 3000W or more. More info: http://www.dvdoverseas.com/store/index.html?loadfile=itemthg2000.html
Oct 11, 2006 | GE JES735WJ Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
