Question about Maytag PYE2300AY Electric Dryer
The dryer is off the light does not turn on the motor is good.
    President:
  • 3,074 Answers
Door switch
Posted on Apr 10, 2011
How can you tell if the motor for the dryer is working
if your inclined to jump the wires to the motor 110 volts it will tell if the motor is good
May 20, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
The dryer won't turn on. The fuses are good, the power is good, the condenser is good and the motor is good. The light on the panel come on but nothing happens. Is it the circuit board?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 26, 2011 | Bosch Axxis WTA 3510 Electric Dryer
The dryer is not spinning andmakingawhining sound.
Possible that the motor is struck of the mechanism is JAMMED. It is important that you must take a good observation of the fault with a good access, use a good light and look for the source of noise. Disconnecct and touch the motor , if this is warm then the motor must be manually turned to see for any jamming. If not check the capacitor which can be faulty not allowing the motor to start.
Jan 20, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer hummes when you turn it on but does not rotate
This don't sound good most likely the motor is bad . OK first unplug the dryer take the belt off the motor now plug the dryer back in hit the start switch does the motor turn NOW??? If not its the motor. IF the motor does turn??? could be a weak motor OR Bad bearing in the Back of the tub.
Rotate the TUB by Hand UNPLUG THE DRYER FIRST. IF the tub Rotate freely I would say you
Have a bad Motor But if the tub is very hard to turn now your looking at a bad Bearing
GOOD LUCK HOPE THIS HELPS
Nov 21, 2010 | LG DLE5977 Electric Dryer
Maytag Atlantis dryer drum not spinning. Light works, there is a hum from the timer, belts are good, drum spins freely, thermal fuse is good. Need to know what would be wrong with the dryer
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
We had 5 inches of water in the basement. ever since our dryer doesn't work. the light comes on, but that's it.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Motor got wet and is no good...
heatman101
Sep 13, 2010 | Kenmore Dryers
Lights come on the dryer but it wont start...any ideas
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 06, 2010 | Samsung DV448AGE Gas Dryer
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
Maytag atlantis dryer
Motor is bad= not worth fixing! Sorry, Buy a kenmore or whirlpool- they are good dryers!!!
Dec 12, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag PYE2300AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
