Question about Kettler KT902129 12" El Toro Bicycle
Is there a place to buy a replacement wheel/tire for the Kettler El Toro 12" bike? My husband ran over the bike and bent the wheel and it is flat!
  • 30 Answers
Of course there is, but if you can't find the same brand you can replaced it with other brands as long as the same size.
Posted on Apr 10, 2011
I have bought a 2nd hand Kettler go Kart with tubeless pneumatic tyres. 3 of the tyres are uninflated and the footpump will not fix them because the tyres have shrunk off the wheel rim and are no longer...
use washing up detergent around the beads of the tire and press them over the ridge in the rim
remove the valve in the stem and use a big capacity compressor to blow the beads in place
replace the valve and inflate as required
r
Oct 12, 2017 | Toys
Wolbel in left front wheel
Does the steering wheel shake side to side while driving it as well? this may be due to a separated tire or bent rim.
Jan 10, 2011 | 1998 Pontiac Bonneville
Wheel is crooked from top it goes in and it i recentley ran over
alignment,,most places will give u a free under car inspection,, it just takes a little of your time,,then u will know if anything is bent,,,,,hope it hoped,,
May 28, 2010 | 2001 Hyundai Sonata
Denali GMC 700C Women's road bike wrong tires!!!
Can you explain why you think the tires are too big? Do they NOT fit the rims? What condition was this bike in when you bought it? If the brake pads line up with the rims then the wheels are correctly sized for the frame.
May 06, 2010 | GMC Denali 700cc Women's Road Bicycle
The car jutters when driving over 60km/hr
Posible problems , listed from cheapest to most expensive.
Tires out of ballance
Broken chord in a tire
Bent rim
Loose ( worn ) tie rod ends
Bent axle
Wheel bearings ( but not likely)
If you have the tools , and a good safe flat driveway , jack up 1 corner of the car , spin the tire by hand and watch if it spins true , or wobles. while your at it , firmly grab the tire , and try to wiggle it side to side , in and out , back and forth. Repeat process for each wheel. If everything seems ok , I would think about getting tires ballanced. Probly about $ 12 each.
General observation is that if you feel the shake in the steering wheel , front tires are the problem , If you feel it on your bottom , rear tires. Good luck with that.
If you want to skip the whole jacking up the car proceedure , go directly to the wheel ballancing , and ask the mechanic to keep an eye out for "wheel out of true" while they spin on the ballancer.
May 09, 2009 | Suzuki Grand Vitara Cars & Trucks
Unusal valve stem on the tire tubes how do I pump?
ok mate you have to go to a bike shop and buy a the newer tubes the one your daughter has is really old and they dont make them any more so just go to a bike shop and ask for a bike tube and then ther you go also if ya need any help putting it on just give us a bell. and dont forget to rate me .
Mar 28, 2009 | Kettler Scoot Training Bike
My bike got a wobbly tire basically right when i bought it
The cheapest way is to buy a new tube to see if that was the problem. Sometimes tubes can inflate bigger at one area than others. If not check to see if the rim is true, meaning that it is not bent, if so replace. It could also be the tire.
Feb 21, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Kettler Air Navigator Tricycle
My husband and I just put this trike together and had a similar problem - the front wheel always turned the pedals and we couldn't figure out how to stop this. The manual for the trike is awful and very hard to understand. After spending a LOT of time analyzing the pictures and doing all sorts of weird things to the pedals, I found a posting on a website that said they'd had the same problem, but had removed and re-attached the front wheel and the problem was suddenly fixed. Sounds too good to be true, right? Well, we noticed that in one of the manual's pictures that the air valve for the front tire was facing the other direction - we'd actually put the tire on backwards. I took the tire off, put it back on facing the other way, and suddenly it all works as it's supposed to.
The thing is, you actually don't have to "do" anything to change from free to fixed and keep the pedals stable. If my daughter pushes the pedals around, they move around, and if she keeps her feet steady on them, the wheel continues to go around while the pedals stay put. It truly is automatic, which the diagram in the manual does a terrible job of conveying.
Hope this helps someone. We like this trike, but the directions are beastly!
Aug 18, 2008 | Kettler Kiddi-o Supreme Stroller Trike
Kettler KT902129 12" El Toro Bicycle Logo
111 people viewed this question
Top Kettler Cycling Experts
Eric Hidle
Level 1 Expert
dante
Donald Ayers-Marsh
Are you a Kettler Cycling Expert? Answer questions, earn points and help others
