Question about Siemens WTXD5300US Electric Dryer
SIEMENS WTXD5322us Electric Dryer no heat. I checked the heat element and I have 10.3 ohms not sure if the thermostat is in the lint area but that reads .1 ohm cant find the thermal fuse if there is one on this model, I do not have a wire diagram
    President:
  • 3,074 Answers
Http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Posted on Apr 10, 2011
What would make our siemens ultra sense electric dryer stop running after about 5 to 10 minutes?
I SUSPECT YOU SHOULD CHECK UR MOISTER SENSOR LOCATED IN THE DOOR OF DRYER.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 07, 2015 | Siemens Dryers
Tip
Whirlpool or Kenmore Dryer Does Not Heat
Electric
First , check the circuit breaker to make sure they are on . Be sure to UNPLUG the dryer , while checking with an ohm meter . When checking WITH power , BEST to have another person available in case of emergency . I do know of 1 person killed while working on his dryer .
A dryer operating on 240 volts , sends 120 volts to the timer and 120 volts to the motor . In between these two , are the thermal cut-off , and the element ( this is the basic operation parts ) . The 120 volts from the motor , goes directly to the element if selected for heat . The timer circuit , sends the other 120 volts , thru the operating thermostats , then thermal fuse , then thermal cut-off , then high-limit thermostat , then to the element . Usually , not ALL the time , the thermal fuse ( number 1 ) is the problem . The heating element ( number 2 ) is usually the problem , if the thermal fuse is good .
If the thermostats , element , and thermal fuse check good with an ohm meter , remove 1 wire from the element and check with a meter , which side is NOT getting 120 volts . Trace the wire which will either go to the timer ( occasionally ) or to the motor ( extremely rare ) .
Gas
On a gas dryer , for no heat , or , heats for a short time then runs but no heat afterwords until cooled down , first check that the electronic igniter , glows red . If it does NOT glow red , then check power to the burner ( 2 wires ) . If no power , then the thermal fuse is bad . (On electric dryers , the thermal fuse keeps the dryer from starting . On gas dryers , it keeps the dryer from heating . The thermal fuse , is a 1" long , or oval , white piece , with 2 wires going to it ) . Also if it does not glow red , the igniter itself could be bad . Again , check with an ohm meter . If the igniter glows red and clicks off , but no gas , the sensor could be bad . This sensor , is mounted to the side of the burner box , and when the igniter gets hot enough to ignite the gas , the sensor opens , sending power to the coils , which open dispensing the gas to heat the dryer . To check the sensor , with the drum removed , start the dryer , and after the igniter gets red , pull one of the wires OFF the sensor , and the gas should ignite . Do this very carefully , as electricity WILL be in the wire pulled off . If the dryer heats for a short time then stops heating , the problem will be the burner coils . These coils will get warm from the electricity going thru them , and will " open " ( short ) internally , until they cool down . Then heat again for a short time , then open , until cooled .
Most of the time , either the thermal fuse ( 1 ) or the coils are bad ( 2 ) or the igniter is bad ( 3 ) .
........A thermal fuse is a white 1" long torpedo looking piece , or , a white oval shaped piece , with 2 wires going to it .
NOTE1 : The thermal fuse keeps an electric dryer from starting and keeps a gas dryer from heating .
NOTE2 : If your dryer heats but the clothes do not dry , then a venting problem is obvious , as a dryer either heats or doesn't heat . Pull the dryer out and disconnect the vent from the dryer . Dry a load of clothes and if/when they dry in the normal amount of time , this tells you either the vent hose is kinked , maybe pushed back too far , or , the outside vent is blocked , or , the vent in the wall is restricted to the outside .
Electric Dryers
NOTE3 : If your lint screen is on top of the dryer , the element , thermal fuse , and thermostats are behind the rear dryer panel ....If the lint screen is behind the dryer door , then the element , thermal fuse ( located behind the lint screen housing ( 2 screws ) , and thermostats , are located behind the lower front panel .
on Apr 17, 2010 | Dryers
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
Maytag Neptune Dryer runs for about 10 minutes and then stops. If we hit the start button it will run for another 10 minutes. It heats up fine while it is running. When this started we smelled something...
Check for lint buildup on the "Hi Limit Themostat" located above the heating element. There is a thermostat kit that you can get and replace all three at once. This will make sure your dryer runs safe and up to its required operational limits. The lint buildup may cause the thermostats to get out of the tolerance. Here is a link to the thermostat kit.
The FixYa Team
Dec 26, 2010 | Maytag PYE2300AY Electric Dryer
NO HEAT
The electric dryer heating circuit is composed of the heating element, high-limit thermostat, thermal cut-off, cycling thermostat, timer, and centrifugal switch. Parts may vary depending on the make and model of the dryer; specify it for a more specific advice. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
The dryer will not heat when any of its components has failed. Check the continuity of the high-limit thermostat, thermal cut-off, cycling thermostat and the resistance of the heating element using a volt-ohmmeter. The heating element has a resistance range of 8 ohms to 12 ohms depending on the make and model of the dryer while the other three components must have zero resistances.
The timer and the centrifugal switch are less likely to cause a no heat problem and must only be checked when the components mentioned above are found to be in operating condition.
Again, specify the make and model of the dryer for a more specific advice.
Apr 11, 2010 | Dryers
Dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Mar 02, 2010 | Whirlpool Dryers
I have a Kenmore Elite Model number 110.64992300. The dryer turns on and spins but does not heat. I have the bottom panel off am looking at the heat element. What should I do to test everything? I have a...
You need to make sure you have 220V first all the way to the dryer. Make sure you have no blocks (lint blockage). Check your thermostats for continuity. Make sure all the wires are disconnected when testing. If they show good check your heating element not only with the ohm meter but take it out and visually inspect it. They can be bad and show continutiy.
Jan 07, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Jan 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
504 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
