Question about GE Kitchen Appliances - Others
The control will not change from low to any higher temp,also their is abusing sound that is coming from the control every 45 seconds or so.I have only used it 6 or 7 times model tksp so20a-15
  • 105 Answers
SOURCE: power cord
You can contact the manufacturer, the address is in the owner's manual. Check your local appliance parts store. Thrift stores often have appliance control & power cords, too. This is helpful for older units.
Posted on Jul 17, 2007
  • 124 Answers
SOURCE: I have a problem with
sounds like its not proofing flame. it has a sensor usually like a needle sticks out into the flame that tells the gas valve the flame lit and is burning so its ok to keep sending gas, if its fails to proof flame then burner shuts down, then it tries to relight 3 times then locks out on fail safe. the blower will sometimes run continually once that occurs to highlight a failed condition. every time you reset it will try again 3 times then shut down. lp gas is very dangerous, even i do not work on it as the gas acts like gasoline and lays around. not like natural gas that disperses well. if you see the flame sensor try gently cleaning it with a little emory cloth. also a loose ground can cause this. check tio be sure any green wires are snug , they actually flow volts to ground through the flame on some to proof, thats why no ground no flame. if that fails then the board is most likely problem. change wire for wire , or get generic replacemant and follow directions exactly. good luck.some ignitors act as a flamre proofer as soon as they are done igniting! rarely do they fail to perform both funtions.
Posted on Nov 21, 2008
  • 458 Answers
SOURCE: The TV cuts off frequently. The screen is blank & no sound.
It is probable you have a poor soldered connection on the power supply board, hence the erratic timing of the TV going on & off. If you are competent with a soldering iron look for dry jointed soldering on the board. If not have a service engineer take a look at it for you.
Posted on Jun 24, 2009
ginko
  • 19396 Answers
SOURCE: bottom freezer temperature rises as high as 35
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Posted on Jul 09, 2009
SOURCE: Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Posted on Jul 25, 2009
Ac does not cool. on max driver side air temp higher than passenger side. neither cools but Freon ok.
Sounds like the blend door is not closing all the way to seal off the heater core. Locate the plenum and the levers that are on it. Check to see which one is for MODE and which is Blend. Make sure they are not broken or loose. Also something that falls in the defrost vents can end up in the plenum and cause problems.
May 02, 2015 | 2007 BMW 525i Automatic
Dryer starts about 45 seconds into the cycle lights come on and then it starts beeping like the end of the cycle. 10 seconds later off. Very warm on top of the machine.
See my tip for buzzing dryer. Check Owner's manual, Troubleshooting. Sounds like air is not moveing and High temp cut off saftey switch doesn't like the lack of air flow. Duct clean? Check air flow from the outdoor vent. Clean vent tube/s
Mar 04, 2015 | Kenmore Dryers
My refrigerator/freezer is warm
If the motor is running but it's not getting cold then you may have lost coolant. Did someone clean the ice out with a knife?
Apr 28, 2017 | GE Profile PSW26P Stainless Steel Side by...
What should the pressures on the low and high side of the air conditioner read ?
low side should be about 30 psi at idle speed, high side 120 to 180 psi depending on ambient temp. higher temp, = higher pressure, as you increase engine rpm to say 1000 low side should drop to 10 to 15 psi & high side should increase about 30 psi. If high side goes over 280- 300psi you have contamination (air) in system or over charged with refrigerant. you will need to recover freon, evacuate & recharge system with proper amount of refrigerant. If the low side drops below 0psi or into vacuum then the refrigerant level is low, you will have to check for leaks , repair leaks & refill refrigerant.
Hope this helps
Paul T
Jun 01, 2011 | 1997 Chevrolet Suburban
Is it normal for the temperature to stay at 210 on my 05 volvo vnl670
temps vary from 190 to 220 depending on the design. what will change this is the radiator cap. it controls the pressure in the system, higher pressure is also a higher running temp. if you didn't change any components then the temp sounds right. if it gets to about 250 then worry
Jun 04, 2010 | 2005 Volvo XC90
What are the high and low pressure specs for my a/c
this really depends on the ambient temp,but as a rule low side 35-45 psi high side 150-170 but this depends on the ambient temp or the temp at the condenser, hope this helps if not get back to me and we'll go from there. please rate my fix as i strive to be the best
May 07, 2009 | 2001 Toyota Celica
95 t-bird transmission shifting problem
use an obd 2 scanner and see if there are any codes. usually a shift control solonoid, but would verify this before changing. scanner can be plugged into receiver below the glove box.
Sep 08, 2008 | 1995 Ford Thunderbird
Ac problems
Sounds like the switches are in the wrong locations , rotate! Thank- you- very-much!
Aug 20, 2008 | Dometic Rooftop RV Air Conditioner
Kitchen Appliances - Others Logo
42 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Sal DeAngelo
christian nielsen
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
