Question about General Electric PFSS6PKXSS Stainless Steel Bottom Freezer Commercial French Door Refrigerator
GE ref mod# pfss6pkxss - no ice - not cold in the ice box either.. need to know how to remove the freezer drawers inorder to check for fan problem.
    President:
  • 2,468 Answers
You should be able to pull out the drawers to where they stop and lift up and over the slide stop catches located in the slides mounted to the walls on both sides of each drawer
Posted on Apr 10, 2011
Water leaking from the freezer drawer. want to check the the drain but do not know how to remove drawer
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | Amana ARB8057CSR Bottom Freezer...
Ice forms on bottom of Freezer drawer on Mod. GB2FHDXWBo1
Leo Ponder
imufo2
Sep 18, 2011 | Sub-Zero 650 / O Bottom Freezer...
GE Monogram ZIDS240PSS Double Drawer Refrigerator freezes items stored. Temp indicator as low as 19 degress F. Turned unit off and back on using touch pad. Touch pad instructions were ignored without...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Sep 09, 2011 | GE Monogram ZIDS240PSS Double Drawer...
My produce keeps freezing in the crisper drawer-the temp in the fridge is set on medium (5) and the humidity level is on the middle setting in the crisper drawer.The drawer is not jam packed with...
Leo Ponder
imufo2
Sep 09, 2011 | GE Profile PDS22SBRR Stainless Steel...
Frezer temp @ -5 ,referagerator @ 47 degrees. how can I get it colder /
determine if freezer fan is running. If not thats the problem.
Remove the back panel in freezer to access the fan.
Check for frost buildup on back bottom of freezer panel
Sometimes this is a auto defrost problem or ice buildup on
freezer coils.
If ice on the freezer coils is restricting air to the ref.
To confirm ice you will need to turn off ref. for 24 hrs and let the ice melt OR remove back panel in the freezer and visually look for ice in the evaporator coils. if it works fine when you turn it on take your mod number to a local Appliance parts store and they will sell and instruct how to fix the Defrost system
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 24, 2010 | KitchenAid KSRS25IL Side by Side...
GE PROFILE SIDE BY SIDE MOD PSS25MGN - NOT COLD - FOOD THAWING!
Sounds like a main control board defective .The one on your refrig WR55X10552 , is on a recall list .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
The new part number is WR55X10656 . I would suggest calling GE , to have them come out and check , as this part and labor , should be covered , as stated by the letter .
Mar 17, 2009 | GE PSS25MGN Side by Side Refrigerator
GDS20SBSBSS FREEZER DRAWER WON'T OPEN
ice will most likely form again.you have a defrost problem.most likely it is your defrost heater.their are a few things that control your defrost cycle.defrost timer,thermostat and defrost heater.most of your newer ref. will also have a control board on the back of ref. or under ref in a usually grey box.but check your heaters first.you will need to take the back panel off in freezer.you will see heater at the bottom of coils.if you have a set of meters you can check for continuity to heater.also your drain below heater sounds clogged.i usually steam out drain but you can use hot water.water should go down drainwhen unclogged.that will prevent the drawer from sticking.
Jan 26, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Fridge not working, freezer is
First, I think it’s important to know that the Ref area has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting up to the Ref side?
If you want mor info to DIY check out: ronbuice.com
Dec 16, 2008 | GE GBS22HCP Bottom Freezer Refrigerator
The freeze section is colding fine but the other half is not.
The Ref side is basicly an insulated box, all the cooling coils are in the freezer that's why they put a fan in the freezer to force some of the cold air over to the Ref. side. There is a small opening between the Ref and Freezer with a door. This door is controled by one of the two settings on the Ref side. One of the controls is for the Temprature usually 1 thru 9 with 9 being the coldest and the other controls the little door. Now, why is that cold air in the freezer not going through that little door?
1. The little door is not open wide enough.
Turn your control to open the door wider. This control may be labeled "Freezer" so, when you turn it to the "Coldest" this closes that little door and makes the freezer "Coldest".
You can't see this little door but you should be able to find where the air comes through and feel the cold air, that is,if the fan in the freezer is working. If everything in the freezer is working and you can't feel any air coming through then your "little door" control is not working.
2. Fan in the freezer is not working.
This is pretty easy to check, open the freezer and listen for the fan running.
3. The cooling coils in the freezer are clogged with ice which won't allow the fan to circulate the cold air over to the Ref side.
On a side by side you can take out the bottom drawer and get a partial view of the coils in the back however, to get a full view of the coils you must take everything out of the freezer, romove the shelves, remove the back pannel. You should be able to see the drain at the bottom right under the coils. This area should be clear whit nothing bolcking the drain hole in the middle.
The coils will normally have a light coating of frost but should not be completely clogged with ice. If they are clogged then your defrost system isn't doing it's job.
Defrost System consist of a defrost timer, heating coils, and a thermal disc. You will need an OHM meter to check these and I can give you more details on how to use the meter and how to check the defrost system. ronbuice.com
Nov 30, 2008 | Refrigerators
General Electric PFSS6PKXSS Stainless Steel Bottom Freezer Commercial French Door Refrigerator Logo
299 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Shehu Pro
Shehu Pro
Joseph Mueller
Joseph Mueller
Are you a General Refrigerator Expert? Answer questions, earn points and help others
