Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
I have a Maytag Centennial medc400vw0 Dryer that is 8 months old and the wires going into the fuse relay are melted away and the metal is burnt, what would cause this and how do I fix it?
kachbibi1
  • 979 Answers
SOURCE: clothes burnt?
Try turning down the heat setting on your dryer. This should help immensely. Dry these types of clothing on say "medium" setting and the heavier things on normal heat.
Posted on Jan 14, 2009
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: looking for diagram to put
Copy and paste this Factory Service manual for the Centennial dryer.
It has all your answers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/79aaf530992e93a0852572c3006587ed/$FILE/8178629.pdf
Posted on Sep 06, 2010
  • 8 Answers
SOURCE: When dryer is drying clothes
the maytag has a bearing made if a cloth material that is at the front of the drum. when this wears down drum is grating off the metal drum support, hence the grinding sound. the bearing is fairly straight forward to replace.
Posted on Jan 31, 2011
heatman101
  • 43501 Answers
SOURCE: maytag dryer mod.# medc400vw0 dont
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jul 02, 2011
My maytag centennial dryer takes almost two hours to dry a load, it is electric I was wondering if I can convert it to gas? Model # MEDC400VW0
No. Among many issues is that the control board is different. But why not fix the unit so it dries as is normal in under an hour. Half of your 240 volts is out? Your heating element is bad. Your fan is loose.
May 06, 2017 | Maytag Dryers
Maytag model MEDC400VW0 continues to run after drying cycle is completed
Sometimes these machines have a cool down cycle which for most people is too long
Dec 15, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
How to switch door side on dryer
Not that simple like it is on a modern refrigerator. The electrical wiring is set up for a door safety switch. That switch can probably work either door swing. The door would need to be reversed and holes cut in the dryer for the latch. The old latch would need to sealed up. It is uncertain that the metal on both sides is capable of supporting the door hinge. In any case it seems like a difficult and doomed task.
Jan 03, 2014 | Maytag Centennial White Gas Front Load...
Maytag centennial mgdc200xwo
look down on the front left side of the front panel,you'll see a plastic cap,pop it off and start the dryer,when you start it listen for a click and look into the hole where you popped the plastic cap off from,if you don't see anything glowing orange inside and don't hear a click when you start it you have a bad thermal fuse part number 3392519 and it's around 15 dollars.unplug the dryer,pull it out away from the wall if it has a flex line on it for the gas,disconnect the vent line and remove the back panel,now look on the left side,you'll see the metal duct that the lint filter slides down into,look to the right of it and down low and you'll see a white part,that's the thermal fuse,if you have a volt meter check the fuse with the meter,you have to remove at least one of the wires when you check it,if you don't have a meter you can pull the two wires off,stick them together and start the dryer,look into the front hole and see if the ignitor is glowing orange and the flame lights,if it does shut it down and then you have to remove the metal duct that the filter slides into and clean it,also you have to clean out the vent line,this is why the fuse popped,the dryer got to hot and popped the fuse,you have to remove the 4 screws holding the duct on and remove the two phillips screws on top of the top panel where the lint filter is,buy the fuse and put it in,doesn't matter what wire goes where,you should clean this out once a year with gas,if your vent line is long you can blow it out with a leaf blower,remove the vent line from the back of the dryer,stick the leaf blower in it and blow it out,first go outside and make sure there isn't a cage or screen or anything blocking the air from blowing out,if there is remove it so it doesn't happen again.if the fuse is good then you have to pop off the front panel and the problem will be inside the cabinet,also while you're in there clean out the inside with a vac.let me know what you find and if you have a meter,if you don't it would be cheaper to buy one and i'll be glad to help you,
May 20, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
Dryer keeps tripping the circuit breaker no problem with previous dryer dryer is only 2 months old
call the store that you bought the machine from the dryer is still under warranty. it sound like you either have a short or a bad breaker
Jul 15, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag Centennial one month old isn't drying the clothes they come out very damp I want to return it if this is the norm for this unit
Sorry to read about your problem, I hope this helps you out.
No this is not normal, I suggest you contact maytag for warranty work, you will have a 1 year warranty, also check yo see that your dryer vents are clean,
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
My dryer is not putting out heat,i dont know what to do?
The front panel has a little plastic cover over a peep hole to check the gas valve operation. You can pry that off and watch to see if the ignitor is getting super red hot to light the gas. In some cases you need to replace the thermal fuse due to overheating(usually blocked vent causes that). The thermal fuse is small, plastic, rectangular shaped, and located on the exhaust outlet area. It has two wire connectors. Remove one and check for continuity. If you read open then replace that and check for ignitor operation. Make sure your vent hose is not kinked and is as short as possible. Use a metal flex hose or duct tube. Stay away from vinyl or plastic as they are a big fire hazzard.
Sep 18, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
239 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
