Question about Rheem Tank Water Heater G75-125, 75 Gallon
Rheem G75-125 natural gas. Water heater ignites and burns as it should for 5-10 seconds and then shuts off. The damper is open. All of the lights on the front cover light in proper sequence. I get 24 volts at both pilot and main valve teminals at gasvalve. I have 10 inches of gas pressure. It ignites and burns for 5-10 seconds then I lose voltage to the gas valve. What am I missing? Also, where does this water heater sense presence of pilot flame - through the spark ingniter cable? Thank you, Dave.
Suggested order of things.
1) Read manual troubleshoot and maintenance sections
Find same-similar manual at Rheem
http://www.rheem.com/products/commercial/water_heating/commercial_gas/
http://www.rheem.com/product.aspx?id=0697944D-D79A-40C1-BDEB-875E48200DD1
http://globalimageserver.com/fetchDocument.aspx?id=c0b73553-5f03-4a5e-8789-4732ffecdccf
Maintenance and troubleshoot sections might help solve problem.
Download manual to your computer as a resource.
2) Post question on pro water heater forum, and include details from manual, and link to manual, so pros don't have to search Rheem commercial water heater page to find manual.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Contact Rheem who will ask you for name of installer and servicing technician.
4) Call service technician.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 11, 2011
Detecting gas and won't light
Open following link for troubleshoot error codes showing 7 flashes on Honeywell gas control valve is system lockout due to flammable vapor:
http://waterheatertimer.org/pdf/Honeywell-gas-control_error-Damper-series.pdf
The FV system in Rheem can be tripped by presence of flammable vapors such as gasoline or paint fumes etc, or it can be tripped if water heater was dropped, or mis-manufactured, or if gas control valve is defective, or if water heater is not getting adequate fresh air, or there is inadequate venting of combustion by-product.
When combustion chamber overheats, then glass vial breaks and damper shuts off air supply to water heater and it will not light.
Open following link for possible help fixing the problem:
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
Jun 13, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheem rtg-74pvn-2 tankless water heater installed in 03/09. Intermittently the hot water stops when only the hot water tap is on. No error codes appear. Bill W.
Before calling service technician, open following links for resources including Rheem chat and possible manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Crossover.html
Typical tankless manual says to have yearly service which includes checking household plumbing, gas supply, vent and condensation, check sensors for loose wires, clean and inspect burner parts and ignition factors etc.
Aug 04, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Having problems with models sutting down. Relates to combustion shut off system. Explain how system works, with corrective action, especially draft system. Pilot ignites, burner operates for second or two...
As a general rule with Rheem gas water heaters, the manufacturer suggests calling trained service technician and their products do not have specific service bulletins.
I cannot explain combustion shut-off adequately. Post question on water heater forum.
Most likely the combustion and combustion parts need cleaning and maintenance, as a start point.
Gas water heaters today require yearly cleaning and maintenance.
That work would cover possible causes and combination of causes: from air in gas line, faulty venting, inadequate air supply, dirty parts, overheating, leaks, exposure to chemicals, corrosion, faulty gas control valve thermostat, sediment build-up.
You have a standing pilot light that is working, so gas supply sounds correct, and ECO is not tripped, so cleaning is major suspect right off.
Light a match under the vent hood and check if smoke drafts immediately upward.
Your water heater vent has a natural upward draft that pulls combustion by-product upward so the poison gas is vented outdoors to kill the world slowly instead of remaining inside the house. If vent is clogged, the air flow might not support combustion. Likewise if water heater does not have adequate incoming air supply, for example a tightly sealed house, then combustion is not supported. Also if you store bleach and pool chemicals and other assorted chemicals in trace amounts in same room or nearby, the burning chemicals will corrode combustion parts so they no longer perform.
http://waterheatertimer.org/images/Test-water-heater-vent-400.jpg
See general illustrations for cleaning combustion parts, and read 2 pdf files about cleaning typical gas water heaters.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Read Reliance gas water heater handbook. It may or may not apply to your circumstance and heater.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Jul 11, 2011 | Rheem 30 Gallon FVR NATGAS Water Heater...
How can I tell how many BTU's my natural gas meter is rated to supply? I'm getting an error code 12 on my Rheem EcoSense 9.5 GPM 199,900 BTU Natural Gas Indoor Tankless Water Heater, so I'm guessing the...
I have a Rheem PTG-74XP tankless. I had the same code 12, low/inconsistant gas problem (assumption). In my case the gas (propane) pressure coming in was fine, the reason the flame rods/electrodes would not burn correctly was residue on/in them. It hasn't happened since they were cleaned. Hope this helps, dj :)
Feb 03, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem Tank Water Heater G75-125, 75 Gallon Logo
233 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
