Question about Pioneer DEH-P4000UB CD Player
I bought the deh-2200ub to replace an infinity stereo in a 2005 kia optima. There's less wires on the pioneer, which I just taped off, I have no sound. AARRRGGGGGG!!!! help
    Habit-Forming:
  • 50 Answers
The most common problem that you will encounter with the kIA is due to the fact that many models have a built in amplifier that is powered up by the factory deck. If your model does not have this option and the deck is properly connected, you should have no problem. First thing to do is get a small speaker that you can hook up directly to one of the pioneer outputs to confirm that there is audio, this will save a lot of time. If it plays, you should consider having the deck professionally installed, as the accessory circuit will be needed to wire in, and the low level inputs will have to be patched into your line level output through maybe an impedance matching dongle. The high level oututs cant be used as is because the amplifier circuit would be overloaded, you would have to utilize a signal level reducer/ground loop isolator dongle because the pioneer units are a floating ground output and would burn if connected to a grounded input. The amplifier unit is located in the back trunk, you could modify it from there to connect the deck output directly to the speakers if you look at the attached diagram, but that would be a waste of a good amplifier. If you're electronically savvy it can be done, or if you know someone who is , these diagrams will help you tie in the amplifier accessory to the remote turn on output of the pioneer deck and do the other mods. Ive done it before, but its not something I would be inclined to attempt to talk you through
Posted on Apr 10, 2011
  • 8,836 Answers
Hi, the wires should be connected as indicated below. Please let me know if you have questions, and thanks for using FixYa.
2005 Kia Optima Car Stereo Wiring Schematic Pioneer wire color
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: Yellow red
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Brown/White none
Car Stereo Dimmer Wire: Gray none
Car Stereo Antenna Trigger Wire: Gray blue/white
Car Stereo Amp Trigger Wire: Green blue/white (same as above)
Left Front Speaker Positive Wire (+): Yellow white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Blue gray
Right Front Speaker Negative Wire (-): Red gray/black
Left Rear Speaker Positive Wire (+): White green
Left Rear Speaker Negative Wire (-): Brown green/black
Right Rear Speaker Positive Wire (+): Orange violet
Right Rear Speaker Negative Wire (-): Green violet black
Where do I find the fuel filter on a kia optima 2005
How to Change the Fuel Filter on a 2005 Kia Optima
www.geeksoncars.com/how_6754168_change-filter-2005-kia-optima.html
Feb 4, 2015 - How to Change the Fuel Filter on a 2005 Kia Optima. The fuel filter on a2005 Kia Optima plays an important role in the fuel system. It goes on ...
'05 Kia Optima - No Fuel Filter? - Kia Forum
www.kia-forums.com/...optima/75444-05-kia-optima-no-fuel-filter.html
Jan 28, 2012 - 5 posts - ‎3 authors
I went to Autozone and bought an inline fuel filter for my Kia... and spent ... Drives: 2004 Optima 2.4 EX, 2005 Yamaha R1 (street) 2001 GSXR ... Do you really need to replace the fuel filter every 30k ...
Jan 6, 2010
2004 kia optima 2.7 dohc fuel filter - Kia Forum
Apr 2, 2009
2007 Optima 2.4L Fuel Filter Location - Kia Forum
Nov 30, 2008
2005 optima fuel filter location - Kia Forum
Aug 23, 2008
More results from www.kia-forums.com
FUEL TANK FILTER REPLACEMENT - YouTube
? 6:50
https://www.youtube.com/watch?v=r3CaW8n-lKo
Apr 19, 2011 - Uploaded by Paulzzila KIA
CITRUS KIA HOW TO REPLACE THE FUEL TANK FILTERINSPECT EVERY 15000 AND ... how to change ..
Jan 05, 2016 | Kia Cars & Trucks
Donde se encuentra el filtro de gasolina de un kia optima 2005
Jan 6, 2010
Apr 2, 2009
Nov 30, 2008
Aug 23, 2008
? 6:50
Mar 03, 2011 | 2006 Kia Optima
The speaker output doesn't work
Hi Marlena,
I had the same problem with the 2200ub, so I will post the solution for that. Hopefully its the same for you, if not sorry I couldn't help better.
I have a 2002 Suburban and was installing the Pioneer DEH-2200UB. The suburban had the factory stereo still and has onStar. So I had everything hooked up, purchased the harness which was perfect except for the blue and white wire on the stereo and a solid blue wire on the factory stereo end. I was confused by there being 2 plugs from the factory stereo and one for the 2200.
I finally went to Best Buy and talked to their tech and he told me that since I have onStar I need to cut the pink wire and wire it to the blue and white wire that goes into the new stereo. These guys were great they didn't hesitate to tell me how to do it and even gave me the extra wire and connectors I would need to do it. Best Buy is expensive but I will keep shopping there just because of their service from these kinds of people.
The pink wire is hooked into the amp which I believe is located under the drivers seat. As soon as I did this everything worked perfectly.
I am not sure if the onStar still works, but I don't plan on using it anyway so if that is important to you, you should probably have a pro do the install. Best Buy will install it for $50 (plus parts) but it could be more for dealing with things like this I really have no idea.
Hope this works for you.
Jan 27, 2011 | Pioneer DEH-P4000UB CD Player
I installed my pioneer deh-2200ub and it won't turn on. I've disconnected it and re-wired everything again and have the same problem. I have a 2000 chevy s10 4x4. Does it have to be grounded for the power...
Turn the stereo off with the button in the top left corner. Hold the button down until the stereo is turned off.
Then push the function button on the remote control and you will see clock settings.
Dec 28, 2010 | Pioneer DEH2200UB with iPod Direct Control...
Find the wirings for a pioneer premier DEH-P780MP
sorry to tell u this but u going to has to buy this cable fron pioneer , cost about $20-$35 , or u can go to a tv shop or car stereo places and see if they have one for less
Apr 15, 2010 | Pioneer Premier DEH-P670MP CD Player
I bought a deh6 pioneer stereo to install in a boat and need a wiring diagram for the stereo itself coming from the stereo
blk-ground
yel-constant 12v
red-switched 12v
blu-power antenna
blu/wht-amp turn on
orn-illumination
Speakers- black stripes are negative.
whites-front left
greys-front rights
greens-rear left
violets-rear rights
tape off any unused wires, do not let them touch ground or any other wire.
Mar 13, 2010 | Pioneer DEH-P6800MP CD Player
I just hooked up a pioneer deh-5100ub stereo in my 2004 dodge ram 1500 pick-up using a store bought wiring harness but I cannot get any sound from my speakers now.
Does you truck say Infinity anywhere on a door panel or such? If so you need to make sure that the blue wire from the store bought wiring harness is connected to the amp turn on from the pioneer.
Mar 02, 2010 | Pioneer DEH-P5100UB Car CD/ MP3 Player
Wiring Pioneer DEH-225 to 1996 Kia Sportage
the difference between constant and switched 12V is the constant is usually for the clock and memory. it draws precious little current. the switched would be for the radio and amp once the car is turned on. You can use tape but either a wire nut (not the pink ones) or a crimp on cap would be better than using tape.
Feb 09, 2009 | Pioneer DEH-225 CD Changer
Pioneer DEH-P4000UB CD Player Logo
321 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
