Question about LG Flatron Ez T910BU 19" CRT Monitor
Hi , The problem I'm facing is that When I switch on my Computer, I can see the screen has decreased and has gone to middle of the computer till the lower part of the computer screen and when I hit either from the side or from the up,it becomes normal and stays there for a while,but again sometimes while doing my work,it again goes to middle of the computer to lower part. Pls. help. thanks.. yogi..
  • 64 Answers
SOURCE: Peculiar Problem in LG studioworks 563N monitor?
Is there anything going on in Control Panel, Power Settings? Such as an auto off? Sometimes getting the monitor to come back on after it goes to "sleep" can be tricky. Usually a keyboard stroke works better than mouse movement. It almost sounds like a hardware problem and I would contact the manufacturer and see if it's still under warranty. I'm assuming the PC it is connected to isn't going off?
Posted on Mar 28, 2007
SOURCE: monitor is dead (power indicator blinks green)
Smacking the monitor works for me. Really.
Posted on Nov 01, 2007
  • 17 Answers
SOURCE: monitor display becomes very bright
Sounds like a dry joint or a dirty control.
In either case, its probably a case off job.. You need to consider this carefully as you are dealing with potentially voltages up to 30,000V. In all honesty, you may be better off going to your local Thrift Storel where they often have screens for under $10.
Before you take the screen apart, look on the back for a couple of holes close together with one marked FOCUS. The other MAY be marked Brightness or SCREEN.
with a longish NON METALIC screwdriver, turn the recessed control gently in the SCREEN hole slightly one way, then the other and then back to its original position. This may remove any dirt/dust accumilation.
I CANNOT STRESS enough, the need for EXTREAM care here due to the VERY HIGH Voltages involved.
Usual disclaimers apply..
Best take it to a shop or replace it..
Posted on Jan 24, 2008
  • 56 Answers
SOURCE: Won't come out of "power saver mode"!! PLS HELP
before anything else... just try to check or diagnose if your video card is not defective..and you try also to use another computer to connect to identify the problem...
Posted on Jan 28, 2008
  • 1684 Answers
SOURCE: Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 19, 2009
Magnetized needs degaussing
proceed with this steps and fix it. God bless you
    • 1 Turn on your Sony Trinitron television.
    • 2 Flip the power switch on your degausser.
    • 3 Maneuver the degausser's coil so that it is a few inches away from the face of the screen. Draw the center of the degausser coil around the entire perimeter of the screen, and then return the degausser to the middle of the screen.
    • 4 Slowly back away from the Trintron's screen. This serves to decrease the degausser's impact on the CRT's magnetic field to zero. Continue backing away until you are about five feet away from the screen
    • 5 Flip the power switch on your degausser to turn it off. The CRT's magnetic field should return to its normal state and the picture quality of your Sony Trinitron should improve.
Oct 15, 2012 | Sony KP-53HS10 TV
Reduce screen font size
your computer screen resolution is very high. Right click on desktop and go to Properties/Personalize option and then click on display and change the screen resolution according to your wish.
Nov 16, 2011 | Dell Latitude D410 Notebook
When i turn it on it says out of range and i have a black screen
Hi, The reason behind the out of range (frequency of monitor) because the video display adapter is trying to set resolution more than what the monitor (screen) is capable of. In this case, try to boot your computer in Safe Mode using F8 function key while starting your computer. Once you are in safe mode, try to decrease the resolution of monitor to the lowest resolution level and apply the settings. Now try to boot computer in normal mode once again, you will get the settings which you have applied in safe mode. Adjust the screen resolution accordingly till the settings work with the monitor (screen).
Mar 01, 2010 | Microsoft Windows XP Home Edition
Acer Aspire 4720Z Battery works till about 32% and then it gives a low battery warning of 5% before shutting down. It wont restart unless its plugged in. The battery shows 5% charge remaining. Where has...
Laptop battery notification is not accurate but approximate. The remaining battery usage is calculated approximately and then notified to the user. If your battery's life is more than a year, then the calculation goes on decreasing. It cannot be rectified unless you go for a new battery. But still you can tweak the battery life by,
1. Switch of the wireless adaptor when not in use.
2. Decrease the screen brightness.
3. Configure your power plan in control panel to minimal power usage mode while on battery.
4. The notification limit for battery low can be custom configured in the control panel. set it to 30 % and this will prevent your laptop to dye without power as your battery power drains faster below 31%
I hope this is helpful to understand the logic behind this.
Sep 11, 2009 | Acer Aspire 4720 Notebook
Green vertical line is coming in the middle of the
monitor is probably going bad. Try hooking up a different monitor up to the computer, one that you know works properly. If the same problem exists then its the video card, if the problem goes away then its the original monitor that is bad.
Aug 16, 2009 | Samsung Computers & Internet
Black screen on my LG Flatron lcd 563le
I solved the problem myself by disconnecting the monitor from the computer and then I unplugged the computer. I restarted the computer in position fail safe (F8) and tried to change the monitors resolution back to origin, failed to do so and rebooted instead. When Windows loaded up the problem was gone! Yipeyiiiii!
Jun 02, 2009 | LG Flatron 563LE 15.1" LCD Monitor
I turn on my mac and only this small folder icon appears in the middle of the screen
The face is probably frowning.  The computer cannot find the operating system.  Use a utility disk to boot up the computer and then use First Aid or Disk Utility to check the disk.  You may have to re-install the operating system.  This can be done without losing your files if done correctly.  Seek help from an Apple repair facility if you are in doubt about how to do it.
May 20, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Gnr ts700 Screen has gone to the Middle Of the monitor
Did the other monitor have the same problem or was it ok? If it's just the one monitor, it may be on it's way out. It is very dangerous to open a monitor and try to repair it. Don't do it yourself unless you know exactly what you are doing. Have you installed anything new in your pc? What about seeing if there is an updated driver for the monitor? The monitor's website - support page - should have a driver update. See if that works. If you recently installed a graphics program, it could be a setting there that is messing things up.
Jun 18, 2008 | Gateway FPD2275W LCD Monitor
LG Flatron Ez T910BU 19" CRT Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
