Question about Ovens
I have a lite gas stove and lighting hit close to my home and now when you try to turn the oven on it says f3. how can i fix this to be able to use my stove thank you deirdre calcote
  • Ovens Master
  • 1,902 Answers
Hello & Welcome to FixYa
F3 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Apr 11, 2011
My oven isnt getting any gas?
All gas ovens have safety features to prevent raw gas from escaping into the home. On older models the pilot light sometimes lows out and the oven thermocoupler cools down. this closes the gas safety valve. On newer stove they have a glowbar that opens the gas valve when it gets glowing wide open.
If ya see a glowbar type and it is dim orange, it is worn out and in need of replacement. Post yer model number for a more precise answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 23, 2011 | Whirlpool Ovens
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Apr 22, 2011 | Viking 27" Professional Select Built-in...
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
Hit the "clean " button on my gas stove. Not only did it not clean but the Door locked button has been flashing for 2 weeks. Everytime I go to cook and it the Bake, Broil key it flashes DR then F9 I h
Personal opinion. Do not mess with settings on a gas stove. Call a gas oven repair tech and have them come out and fix it. That way if it happens again you have someone to call
Nov 03, 2017 | Frigidaire (FEB30S7D) Oven
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Oct 08, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
MY STOVE
hi thanks for the question .F3 on a Frigidaire stove means that the oven sensor is open that's the part in the oven to the left and top it looks like a pencil replace part from the back of the stove but with 1 screw holding the sensor replace BUT power off please thanks the appliance doc
Sep 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Whirlpool oven model sf315peew Super cap 465
try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
Jan 30, 2008 | Ovens
Code E2 F3 shows on Whirlpool gas stove readout
Wisco, this is a code for a overtemperature. You want to check the temp sensor in the oven. You need to ohm it out. Should read 1080 ohms at 70 degrees. If the sensor checks out ok, then I would suspect a welded or closed relay on the control itself. Catriver.
Sep 12, 2007 | Ovens
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
