Question about Refrigerators
I have bought Panasonic Fridge in Sept 2010 Model No is NR-BU 342 - 2010. There is some problem with the door of Upper compartment.. Because of the Gel applied on the door opening seal, it is too tight to open. When it is opened forcefully bottles kept on the door shake up and the balance of the fridge also gets disturb. Once I have cleaned the door opening seal by wiping it softly as suggested in the operating instruction book. I called for the service from the company. But he could not solve the problem. Please help
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
lenwest
  • 150 Answers
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
  • 351 Answers
SOURCE: freezer door pops open.
door adjustment may be needed and or a new seal is what i would recommend
Posted on Apr 28, 2009
Problem with varying temperature.
Sounds like an air-flow problem, are the fans running? Damper door open? Model #?
May 26, 2016 | Hotpoint RLFM171P White 342 l Fridge A...
How do I turn demo mode off on FGHS2631SS Frigidaire?
Are you sure you have the right model #? Your refrigerator's model number may vary by type. The model number of a top freezer refrigerator can be seen along the upper left side wall of the fresh food compartment and is visible when the door is opened. The model number of a french door and side-by-side refrigerator can be seen along the upper right side of the fresh food compartment and is visible when the door is opened. model-number-refrigerators.png
Sep 10, 2014 | Refrigerators
Fridge/freezer not cooling
check the door switch ok or not
if the door switch not ok replace it if ok ch the cooling cycle
Mar 16, 2014 | Siemens KG34NA13GB
2010 can am spyder rts front compartment door switch can't open the compartment door
Hi, Mike sorry you can't find the first and best tool you ever bought for your CanAm despair not for a mere $30 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Too much junk in your frunk Unstick your front trunk lid
Thread Locking glove box
2014 CanAm Spyder RT Series Repair Maintenance Parts Master Collection...
Can Am Roadster OEM Parts
http://www.spyderlovers.com/RT/NEW2010RT.pdf
Jul 28, 2012 | 2010 CanAm Spyder RTS
Panasonic Inverter fridge NR-D512X
Most likely the inverter itself is causing that
Jun 28, 2012 | Refrigerators
Panasinic PV-GS300 Will not accept Tape. Immediately ejects new tape
Hi there, you should spray inside cassette compartment a contact cleaner spray carefully aim on the upper right position there's a cassette in sensor ,maybe needs contact cleaning.if problem continues the mechanism unit must be replaced,only drum has a part nr all the rest goes as a unit with only one part nr.
Nov 14, 2009 | Panasonic PV-GS300 Mini DV Digital...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
