Question about Little Tikes Cozy Cruiser 7990
Both wheels on the cozy cruiser are not perfectly round, so the tire tends to slip out (while riding and I don't notice because I'm looking ahead) and causes the inner tubes to pop. The plastic rims are some what cheap? I've tried many things to correct this and played with the tires pressure to try and make this expenditure worth while. Being a mechanic I can only say that overall the trailer is great, but the cheap plastic wheels just don't cut it. If this issue was resolved with a better quality "harder" plastic this issue wouldn't even exist.
    Brigadier General:
  • 8,546 Answers
Rough ride and sliding on snow
Hi Susan, This sounds like a tire problem. I find on my Suby's, that too wide a tire will tend to struggle with deep snow. An out of balance tire or out of round wheel can also make the car run rough. There is also the possibility that the car needs a wheel alignment. Have someone check out the steering components as well, to make sure there's not a more severe problem, i.e.: axles; ball joints; steering arms. This is critical so you can be sure your vehicle is road worthy.
Feb 05, 2014 | 2004 Subaru Forester
2008 street glide rear wheel wobble
Hi Anonymous, and the usual suspects are:
1. Improperly loaded motorcycle. Non standard equipment on the front end such asheavy radio receivers, extra lightning equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tire(s) or improper front-rear tire combination
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. Shock absorber not functioning normally.
7. Loose wheel axle nuts.
8. Excessive wheel hub bearing play.
9. Improper vehicle alignment.
10.Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires out of round or eccentric with hub.
13. Rims and tires out-of-true sideways.
14. Shock absorber improperly adjusted.
15. Worn engine stabilizer links.
16. Damaged rear engine isolation mounts.
17. Swing arm pivot shaft nut improperly tightened or assembled.
Good luck and have nice day
Dec 17, 2013 | 2008 Harley Davidson FLHX Street Glide
Noise from the front right tire
Careful, the tire may be delaminating! Look at it carefully for any signs of damage. Jack up that wheel and spin the wheel, see if the tire has bulges or is running out of round.
If any thing but perfect, get another tire.
Nov 28, 2013 | 2005 Isuzu Axiom
I need pictures on what the axle is suppose to look like where the tire goes on and also what both sides of the tire r suppose to look lil on a Craftsman DLT 3000 riding mower. Someone please help this...
The first wheel and tyre in the video is complete, the second wheel in the video has the bearing and bush missing from one side, the bearing and bush are still on the axle that you are pointing at, they need to come off the shaft and press fit them back into the wheel, the mark around the outside of the tyre is a bead, this if fitted shows the tyre is true on the wheel, this is not so important on a slow moving tractor.
Jul 21, 2013 | Garden
2009 FLSTC. slight vibration and wheel wobble.
Aug 01, 2012 | 2009 Harley Davidson FLSTC Heritage...
Craftsman DLT 3000 Lawn Tractor, Model 917.273821. Two problems for which I'd appreciate any help: Problem 1. The front wheels are not aligned. The left front wheel cants out to the left so much so...
Problem 2 is probably a belt slipping or a pulley loose somewhere.Problem 1 .........is the tie rod adjustable?If the tie rods are adjustable, put steering wheel where it's supposed to be when straight, then adjust tie rods so that each wheel is pointed straight ahead. There should be a lock nut that needs to be loosened, then turn the tie rod end in or out and tighten lock nut. Back to problem 2....if it isn't the belt or pulley, it may not be an easy fix.Sometimes over time, belts stretch and get loose, or a set screw in a pulley can work loose, and cause the pulley to slip on the shaft. If it is hydraulic, it might be low on fluid.. I don't know for sure as I am not a big fan of Craftsman lawn tractors. Good luck
Apr 16, 2011 | Garden
Little Tikes replacement wheels
Last time same wheels I bought it from amazon. take a look here Kids Tell All Hear about their favorite new toys I hope this was helpful. cheers
Oct 04, 2009 | Little Tikes Cozy Coupe
We just bought a 2008 PT Cruiser with brand new tires on the front and am noticing tire noise at 40 and 55mph. The noise goes away just as you pass these speeds but come back around when you slow down. The...
it could be the type of tires. depending upon tread design an purpose of tire. ie mud and snow, high performance. i would ck to see if the tires are directional. if they are and someone unwittingly rotated the wrong it would do this. you should be able to tell by looking at the sidewall. there should be an arrow showing proper rotation.
Sep 17, 2009 | 2008 Chrysler Pt Cruiser
Need tire size for 1995 Toyota Land Cruiser Prado
Big tires:
1. Hard time for your drive train (clutch, cv joint, tranny, diff gears) , power steering, brakes
2. Slow acceleration
3. possible fender damage
4. turning radius problem
5. increase body roll and instability
Advantages:
1. good ground clearance
2. softer ride
3. Enhanced off-road ability
tires your planning to buy can fit into your existing rims.
My personal opinion is for you to go for the bigger tires!
Dec 04, 2008 | 1995 Toyota Land Cruiser
Little Tikes Cozy Cruiser 7990 Logo
140 people viewed this question
Top Little Tikes Cycling Experts
John Egan
John Egan
Are you a Little Tikes Cycling Expert? Answer questions, earn points and help others
