Question about Husqvarna Garden
I have a Husqvarna 150 BT X Torg. It is 2 yrs old & it starts but dies & I start it again but oes the same thing in just a few minutes. HELP
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
The symptom your describing is most often caused by the primer bulb/pump getting a pin hole in it. See this link Item 17: (PN 544363901)
http://www.partstree.com/parts/?lc=husqvarna&mn=150+BT+(2008-10)&dn=89_55_0033
It can however be caused by diaphragms that have failed inside your WYA-79 carb. If you do not have a primer bulb problem the next step is to rebuild the WYA-79 carb with a diaphragm kit.
net IMAGE search using this: Walbro "WYA 79" "Carburetor Kit" They average $13.99
The carb Manual:
http://wem.walbro.com/distributors/servicemanuals/WYAseries.pdf
Dried and cracked fuel lines can cause the same symptom you describe also.
Thanks for choosing FixYa,
Kelly
Posted on Apr 10, 2011
Hey plz tel me why my xl110 dies on me every +- 1km wen i ride.then i hav2 runstart it again 2 reach my destination.i kick myself blue in da face bt no help.wen i just idle da bike;after a few minutes just...
Sounds like the gas tank isn't venting.
If air isn't allowed to enter the gas tank to replace the gas flowing out, vapor lock happens.
Next time it dies, remove gas cap and see if it starts quicker/easier, and runs longer.
If so, then you have a plugged vent.
Jan 16, 2014 | 2010 Vuka XL 125
Car idles rough upon starting then smooths out but sensor light is on. Replaced oxygen sensor 2 yrs ago. Any idea what sensor it could be?.
Maybe your coilpack? The humidity isnt good for old coil pack! after few minutes the heat of the engine dry it and run better
Jan 12, 2013 | 2002 Ford Taurus
Have Husqvarna YTH 150, good gas battery charged starts runs for 30 minutes and stops?
is it loosing spark when it dies?like the coil is bad or there's a nest under the cover and the coil is overheating
Aug 04, 2012 | Husqvarna Owners Manual Yth150
Good morning! My 1990 Toyota Corolla 2 Door Sedan has been fine until the past 3 days. The car starts fine then several minutes after driving the car will die. I pull over on the side of the road, put it...
this may be a few things, the most common is a bad ignition coil,this looses spark and car dies, then after cranking a few times it will start to work again, the problem can also be a fuelpump doing the same thing, the best thing would be to check for spark when it dies but you would need someone to spin the engine while you were to see if the sparkplug wire was sparking,another common thing is the distributor itself or the cap, see this can go on and on without a good diagnoses you can throw parts at this car all day, it would be cheaper to have someone test it, they would need to drive it until it stalled and then do some quick testing before it started and this may take a few days because you said after a few times it will run fine,
Dec 10, 2010 | 1990 Toyota Corolla
Hi i have a honda CM125C 1985 MODEL. it keeps blowing spark plugs. this caues it to flood and not start. when it does start it will die one me or move but very slowly and then die. i have cleaned the...
Check your standard factory specs for spark plugs, it sounds like ur bike getting OVERHEAT!
Did you happen to check the over head valve camshaft? Ussually that bike , w/ age happen to be more tha 10 yrs old, cam shaft, valve guide are worn out and out of clearance! Check it please!
Hope that make your bike be reliable again!
Nov 07, 2010 | 2000 Honda CM 125 C
I HAVE A HUSQVARNA YTH20K46. IT STARTS AND THEN DIES. IT WILL NOT RESTART. ABOUT 15 MINUTES LATER IT WILL START AGAIN AND DIE AFTER ABOUT 5 SEC. IS IT STARVING FOR GAS?
when you say it will not start, will it tun over?
or will it make one revolotion and stop?
it maybe be getting tomuch gas and flooding make sure the choke is off.
Feb 28, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Honda Dies While Driving
The two most common problem with these Honda's are the distributor and the "main relay"(this control the injector and fuel pump. Most of the time with a distributor problem you would get the problem that you have described. So in my opinion its a distributor, can be replace very easily. Contact if you need more help and thanks for using FIX YA.
May 15, 2009 | 1994 Honda Accord
I have a 89 ford f 150 lariet
ignition module is suspect here...good luck
Dec 18, 2008 | 1989 Ford F 150
Garden Logo
458 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
