Question about Daewoo Televison & Video
Date keeps resetting to 27.03.2011 I have tried unplugging,changing the date and going back to factory default and reinstalling but nothing seems to correct the problem therefore unable to use timer
This is the date the clocks went forward, try to put in correct time and switch off auto update this may stop your recorder looking for the updated time codes sent from your local station which may be interfering with your machine
Posted on May 08, 2011
  • 635 Answers
Most DVR's don't have back up battery for holding setup data like your Computer. That means that you can never unplug or switch off the power supply completely. The clock runs off the mains supply so any interruption will make it revert back to factory settings.In other words you have to put it in standby mode when not in use to retain recording schedule / clock time etc.
Posted on Apr 10, 2011
My kindle fire will not charge. Lightening bolt appears,says charging but the % does not change. I have unplugged everything, turned it off and on, and changed receptacles. What do I need to do>
Try using a different charger and cable to make sure the battery is being properly charged. Your penultimate option is to back up all your files and perform a factory reset. Go to Settings > Device > Reset to Factory Defaults > Reset. If nothing has worked, then it's time to contact Amazon.13 Jun 2016
Kindle Fire: 13 Common Problems and How to Fix Them ' Digital Trends
www.digitaltrends.com/mobile/kindle-fire-hd-problems/ kindle fire will not charge Google Search
Dec 16, 2016 | Tablets & eReaders
I have the JVC digital minidv camcorder, Model No. GR-D270U an it keeps telling me it's in safety mode and I can't even get the tape out beause the door opens but it's like the mechaism to pop...
After trying the remove-and-reattach-battery exercise, I would suggest you go to the menu and find the setting for initial setup. Select that - which may reset the system.
If not.. then try going to the clock and change the date/time settings, turn the camera off, remove-and-reattach the battery. Re-power the camera, go back and change date/time setting to what's current. And try to eject the tape.
On one of our analog video cameras it seems like there was a tiny little hole someplace on the side of the camera that you could use a tiny small thing like a toothpick to press in there to accomplish a Reset. (It will have tiny raised letters saying "Reset" right beside the little reset hole.)
May 16, 2011 | JVC GR-AXM270 Hi-8 Analog Camcorder
Hi i'm unable to use my belkin 54g as anything other than a wired connection my laptop and wii sometimes don't even find it as an access point when it does it won't let me connect with or without a...
Wau let me resolve it for you.
o restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the back of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
do this operation 3 times after this your router will go to factory settings
after go to command prompt and ping router like this.
ping 192.168.2.1 and press enter
you will get 4 reply same and 4 packeges= send / 4 packeges= receive and /0 packeges= lose
is you receive this answer you are ready to configure your router again.
also please type .
ipconfig and press enter the answer need to be like this
ip address 192.168.2.2 sample
subnet mask 255.255.255.x
and default gateway 192.168.2.1
good luck and please rate me techbelkin
Oct 26, 2010 | Belkin (F5D7230-4) Router (587009)
I am trying to set up my wireless router but when i try to key in my user name;which is admin,it keeps telling me its the wrong username
Are you trying to access the router settings page.
Try admin in the user name and admin in the password.
If that is not working, the password of the router might be changed.
The default password of the router is ' admin ' nothing in the user name ( leave it blank ).
If nothing is working then you will need to reset the router.
press the reset button on the router and hold it down for 30 seconds.
Release he button. wait for 30 seconds. now unplug the power cable from the router.
Plug in the power cable. wait for 1 minute.
Now try to access the router setup page again with the admin password.
Once you reset the router , it will come back to factory default settings.
You will need to reconfigure the router.
Click Here for more information about the routers and network
Jul 30, 2010 | Computers & Internet
Printer error
There can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on
press copy
Or if you need to do a factory reset
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 18, 2010 | Dell 926 All-In-One InkJet Printer
Just replaced color cartridge on my Dell 942 printer - not getting an error 1203 message! HELP!
Hi
Error 1203 Dell 962
or
press copy
Feb 25, 2010 | Dell 924 All-in-One InkJet Printer
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
  4. Enter the time, date and language, the press the Select button.
Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
Alarm doesn't go off when set. I've adjusted the time. Still nothing
Try removing the battery and unplugging it form the wall for a few hours. This will allow the microprocessor time to discharge and reset to it normal functions. After letting the Clock/Radio discharge, you can put the battery back in the Clock/Radio and see if it has reset itself to the factory setting.Then use the link (http://www.emersonradio.com/owners) copy the web page link and paste it into the address bar of you browser. It will take you to Emerson home page for owners manuals. There you can find your model clock radio and follow the instructions for resetting the clock radios functions. I hope this information helps you with your problem.
May 20, 2009 | Emerson Smartset Clock Radio
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Televison & Video Logo
123 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
