Question about Creative Labs I-Trigue 3220 Computer Speakers
My speakers were working for 3 years, all was ok, but suddenly I deleted something, and they stopped to work!
  • Creative Labs Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 10, 2011
  • Brian Sullivan
    Brian Sullivan Apr 10, 2011
    just incase you dont have a motherboard disc there are free sound drivers from cnet download.com http://download.cnet.com/Realtek-AC-97-D...
Logitech speakers suddenly stopped working
try first unplugging the speakers overnight then if they sitill dont work try cleaning off connectors i know this is really basic stuff but sometimes it works
May 21, 2012 | Logitech Z506 Surround Sound Speakers
Speakers stopped working suddenly? how can i fix iy?
Hello
A sudden stop of sound output while the set works denotes either its speaker or audio output IC damaged. Check the speaker first by using a multimeter for its voic coil continuity. If speaker is OK, the fault is surely with the audio output IC. It should be replaced with same type and number. It is a semi-skilled work, you have to open your tV, locate the audio output section. You must have knoledge in electronics to do this work. OK.
Dec 18, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
Packard bell speakers are not working, I can hear a rustling sound so there is some connection.
all of a sudden my additional speakers stop working was working ok before help me to check it or test it bplz
Nov 24, 2010 | Packard Bell Speaker Computer Speakers
My built in speakers stopped working. i think i accidentally deleted something i shouldn't have. what should i do to get sound and video back on my laptop?
Since you say that you accidentally deleted something, my money would be on the drivers. Does it work with external speakers?
Aug 07, 2010 | Computers & Internet
Dell speakers quit working on Internet
i had the exact problem! it didn't work but when i tested it they worked! probably you have a virus that deleted some of your C\Windows\System32 files. Reinstall your windows. there is nothing wrong with the speakers don't worry. reinstalling windows will solve the problem
Apr 05, 2010 | Dell A215 Computer Speakers
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
Stopped working
Sorry I don't have a solution, but the speakers have done the same with us. Power comes on, some sound like the wire shorting out, but otherwise no sound. Tried different connection wires, different computers (mac and pc) but no go on any of them. So, I also don't think it has anything to do with you deleting some files.
May 11, 2008 | M-Audio StudioPro 4 Main / Stereo Speaker
Left Speaker Stopped Working
I think I had a similar problem. My speakers were brand new and after a while I lost my front left and rear left speaker. I'm not sure about you guys but after fiddling around with the settings it worked after I changed the "S/PDIFoutput sample rate" from 48 to 96 khz. I have no clue what I did, but it worked for me. I am running logitech something or rather speakers with VIA HD audio deck drivers
Apr 24, 2008 | Altec Lansing VS4121 Speaker
Creative Labs I-Trigue 3220 Computer Speakers Logo
119 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
