Question about Hoover HTC243 Top Load Washer
Hoover 200M sometimes (fairly often) stops during Spray Rinse or during the Spin Dry cycle. I thought the load was unbalanced and after redistributing the load, it works, but only after many attempts. Most of the time the load looks balanced and if I just open and close the lid, it tries to start a number of times and stops but eventually it will start and complete the cycle. It looks more like in intermittent fault then the detection of a true unbalanced load. Is there some module that could be checked or replaced? Thanks Dan
  • dan_voican Jun 18, 2011
    As advised, I replaced the belt (which was in a fairly good condition). This has improved the situation, but the machine still stops sometimes, but not so often. It seems it is very sensitive to the load balance.
    I have tried to look at the electronic motor control module but I couldn't find it, I don't think it has any electronic module, which I was advised could be another cause of the fault.
  • 4,323 Answers
Hi
The issue can be either with the belt that is broken or worn out and should be replaced or the motor control board is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on May 28, 2011
Ge toploadwasher that does not get water out of clothes after final spin
Could be that the spin cycle is not rotating at the required speed to wring out your clothes. Check that the cycle completes at a significant speed to generate centripetal acceleration forcing out the water. Perhaps the load is unbalanced which can trigger the spinning cycle to repeatedly stop during the spin cycle.
Jan 31, 2015 | GE Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Hoover 200m Top Loading Machine Spin Cycle Too short
no not normal many different things can be wrong need more info
May 08, 2008 | Hoover HTC243 Top Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Jun 14, 2006 | GE Profile Prodigy WPSE4200A
Hoover HTC243 Top Load Washer Logo
73 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
