Question about Bose Lifestyle 35 System
My bose remote has stopped working..tried changing the batteries but it still does not work..help
  • 4 Answers
SOURCE: Remote stopped working
http://www.fixya.com/support/t320518-bose_321
Posted on Jan 13, 2008
SOURCE: Bose 321 Remote not working
DEAR
YOUR REMOTE MAY OK PROBLEM IS WITH YOUR SYSTEM PL CHECK IR SESOER
THANK YOU
Posted on Jan 26, 2008
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Posted on Jul 04, 2008
SOURCE: Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Posted on Sep 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have bose remote RC38T1-27 which stopped
$60 delivered...
http://cgi.ebay.com/Gen-Bose-RC38T1-27-Remote-Control-Lifestyle38-48-35-/270732947308?pt=LH_DefaultDomain_0&hash=item3f08f0ef6c
or try this advice to resuscitate your old one:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
Posted on Apr 24, 2011
Stopped working
Assuming that replacing batteries makes no difference the remote has broken.
Buy a replacement from Bose or buy a 'universal' remote from any electrical store. With the latter you will need the appropriate code to link the universal remote to your equipment. Try this website for remote codes http://www.xdiv.com/remotes/
Feb 18, 2011 | Bose RC-18S Remote Control
Bose 321 dvd and remote
hello.
Clean out the battery connection inside the battery case. Incase this work disassemble your remote and find any fault connection in it. or let the repair man do it.
If the remote work change the setting press PBC mode this will change the color. or refer to the manual for changing view setting.
melnavz
Mar 31, 2008 | Bose 3 2 1 GSX System
Remote does not work, battery is good. Can I program my dish network remote? If so what codes can I use.
Sorry to hear about your original remote; we would be happy to help you with addressing your DISH remote to your Bose Wave Radio. Here is a list of some of the codes that we havefor Bose Wave Radio: 761, 664, 656, and 639.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Bose Wave Radio provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Bose Wave Radio. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 21, 2010 | Bose Wave Radio II
Bose 3-2-1.
Sep 07, 2009 | Bose 3 2 1 GSX System
Stopped working. replaced batteries and still
well 1st of all try to check if there is any corrosion on ur remote terminals if there is not try to check the voltage of each baterry also check if there is any corrosion but if not try to install the baterries back again and bring any mobile phone then try to see the video of the outout signal from the remote when u press and hold on any button on the remote at the same time u must direct the remote closely to the mobile phne camera so if u see the light of the IR LED then the remote works but the problem is from ur IR receiver on the device but if the IR LED is not blinking then u must dissassemble the remote and change the IR LED with new one or u must change the ceramic crystal
Jun 29, 2009 | Bose Televison & Video
Bose wave music system
Check remote and replace its batteries.
Does this remote work on any other device?
Sep 16, 2008 | Bose Wave Radio
Remote control problem
Replacement remotes for my AWR1 were $10 from Bose. Order online; receive by mail. I just bought two.
Jun 01, 2008 | Bose Wave Radio
My bose 321 system remote control sometime works and sometime doesn't.
When we try to use the remote the red light glows which I never saw glowing when it was working properly.What could be the problem?
Jan 03, 2008 | Bose RC-18S Remote Control
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Bose Lifestyle 35 System Logo
111 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
