I dropped my lap top and the battery came out,when i put the battery in it had lost the wireless connection.i pressed random buttons and after a while managed to reconnect,if it happens again i have no idea what to do what is the key combination to reconnect
  • Ian
    Ian Apr 10, 2011
    Hi, what make/model is the laptop?
    Problem Solver:
  • 40 Answers
Hi Good Day,
1) May we know the brand of your laptop so that we can give you exact key combination to reconnect to the wireless connection.
2) If your using windows program try these steps:
click on the START button then look for the word CONNECT TO and click it then choose your wireless network name (SSID) for you to be able to connect back to your network.
Posted on Apr 10, 2011
Lap top wireless connection to internet router
you need to turn on the wifi button on router
Feb 16, 2014 | HP Compaq nx6110 PC Laptop
Put phone and usb cord in the lap top to charge...it says software unsuccessful..when i tool the phoen out..and shut it down..the computer wont come back on,,and a little orange light on the side is...
HEWLETT-PACKARD Pavilion dm4-1265dx Notebook
The flashing orange light could be the indicator to tell you that your wireless adapter is working and has a connection to your routericon1.png, if you are not wireless, press the button that is flashing and it will disable your wireless connection,to turn back on press it again.
Or there is another smaller orange indicator which tells you you are runing on battey and it is in need of charge
Aug 21, 2011 | HEWLETT-PACKARD Pavilion dm4-1265dx...
Lost CD & Manuals For instructions To connect Printer To LAP TOP Need Info. How To Install Same Thanks
Click on the link below to download the software for installation.
Choose the operating system and download the DRIVERS. ( usually 32 bit is common PC Operating system for XP, VISTA or Win 7 )
Download Drivers
User Manual
First step is to run the wireless setup wizard from printer front panel
Press the Setup button on printer front panel - Press OK
Use the arrow keys and locate Network Connections - Press OK
Locate the Wireless Setup Wizard - Press OK
It will search for the network Name ( SSID )
Enter the network key if your network is password protected.
Press OK
It should give you message as printer connected to network.
Run the software driver file that you have downloaded and choose the Wireless option to continue with installation.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 07, 2010 | HP J4680 Office Jet All-In-One Printer
Cant install my mouse on my lap top--i need a manual. mgwpkw@gmail.com
You don't require any software to install wireless mouse . Just connect the sensor in USB port and place new battery in mouse . In sensor there will be a button and in mouse also there will be a button . Synchronize both the device for some time by pressing the button , thats it mouse will work properly.
Hope this helps.
May 12, 2010 | Microsoft Wireless Notebook Optical Mouse...
My wireless connections will not work! last night both lap tops and my daughters zip it were unable to establish a wireless connection. It happened once before about a month ago and were able to...
OK, to clarify.
Ethernet = modem?
Wireless box = router?
Do you have hardwire connection to router?
Check the wireless settings in router with hardwire connection.
Most routers use random channel search for wireless.
I usually set this for to use one channel only.
Stops random interference and connections.
FYI: Most routers are on 2.4ghz - same as cordless phones and some hand radios - the frequencies over lap sometimes - even though they aren't supposed to.
Microwaves will also disrupt signals.
Apr 04, 2010 | Computers & Internet
I have a Toshiba lap top A 105. I have lost my internet
It is possible to disable the wireless connection with the keyboard. Try the combination of Fn and F8 buttons (this is a common Toshiba shortcut) to turn it back on. If that doesn't work, look at your Network Connections (through the Control Panel, assuming a Windows OS, if needed). Check the settings and if it is enabled. In the device manager, check if the wireless adapter has an exclamation point in a yellow triangle. If you have the exclamation point try letting Windows repair the driver. (You may need to access the Toshiba website for the correct driver. Either use a different machine and put the driver on a disc or USB driver or your machine's wired connection.) If that tells you it has no problems, remove the wireless connection (and uninstall the driver) and reboot the computer and it should see new hardware and start reinstalling the driver. Then you can try to establish a new wireless connection.
If the above solutions do not help, it's likely to be a hardware failure. You could get a new wireless adapter (USB or an appropriate card for your laptop add-on card slot), use the wired network (if that has worked), or consider a new machine.
Nov 15, 2009 | Toshiba Satellite A105 Notebook
Just bought a new lap top have a wireless router on my PC but want to connect to the internet on my new lap top which is wireless enabled, it has picked up the router which is still named as default but...
From your PC (not your laptop):
Click START
Click RUN
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Find the line stating "gateway 192.168.xxx.yyy"
Start Internet Explorer
Type http://192.168.xxx.yyy
Login to your router
Click the "wireless configuration" button
Set a new security-key or passphrase.
Now, try connecting wirelessly from your laptop, using the new security-key or passphrase.
Sep 19, 2009 | Computers & Internet
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
My laptop suddenly cannot connect to the router.
It comes down to a few things with routers and wireless connections:
1. If you have been dropping the signal over the past few weeks try doing a test on the wireless network connection via the diagnostic tool within the specific wireless connection.
2. You may have gotten a bad update to the wireless card. Try uninstalling it and then reinstalling it.
3. Try deleting the wireless connection for your router and then make 'a new' wireless connection.
Oct 15, 2008 | Belkin (F5D7230-4) Router (587009)
I have lost connection with my wireless
I have gigaset siemens SE568 modem i call siemens company to get password so
that nobody can access into my wireless the problem now i can't access to the internet through
my lap-top i tried so many times i put the same security passphrase but no use now i don't want
to enable password i want to disable it cause i need to use the internet though my lap-top
as wireless please help me
Sep 11, 2008 | Belkin Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
