Question about Intel Server Board S875WP1-E (S875WP1LX) Motherboard
I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
  • bruce jache Apr 10, 2011
    i purchased 4 x 1gb PC 3200 DDR 400 MHZ in matched sets from same vender at same time.when i installed them it would not even boot to bios.when i removed one of them and put in a 256 mb it booted but did not show the other three.
  • 33 Answers
The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
Third party memory vendors may use the same module part number with different
DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
Posted on Apr 10, 2011
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Hi. i have abit motherboard nf7 s2. i bought 2
Did you make sure to install the memory starting from DIMM3? You should install into DIMM3 then DIMM2 according to the NF7 manual.
Mar 14, 2010 | Abit nForce2 NF7-S2 Motherboard
Installed PNY 512 DDR PC2700 Optima memory, recommended by Staples. on to Toshiba P35 S609. System doesn't indicate that memory has increased. Type "chkdisk" into "run" message says doesn't recognize...
First of all it is good practice to have equal brand/model/specs memory boards when installed few of them. Also, you did not mention the bus speed of your PNY DDR, for P35 it should be 333MHz, so at least makesure both or DDR boards there have same speed 333 or else it won't work.
Sep 14, 2009 | Computers & Internet
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
Can't find the primary memory for a elitegroup a535 laptop
a manual can be found here along with the software drivers
http://download.ecsusa.com/dlfileecs/manual/desknote/a535/English%20Manual.pdf
On board 128MB DDR RAM ( primary cant be removed from motherboard)
Expansion 1 slot of 200pin DDR SO-DIMM DDR Module, 640MB total memory capacity.
Supports DDR200 / DDR266 module
Dec 18, 2008 | EliteGroup ECS A535 Notebook
ASUS M2N-SLI Deluxe Motherboard Dead
ulplug cell & HDD SATA/ATA Cable with DDR 1 400 FSB RAM with some brand quality
than boot your system .
Oct 04, 2008 | Computers & Internet
Continual reboot with second memory module
Your memory isn't an exexact match. The 512MB you have in is probablyis Kingston, part # KT3311/512, PC2100/2700, 512MB DDR. You should get Kingston part # KT3311/1G, PC2100/PC2700, 1 GB DDR. You can use another manufacturer but everything must match exactly execpt the size of course. The speed, DDR, everything. Make sure you have the new chip seated correctly and in all the way first. Of course if it doesn't match the specs of your other chip it won't matter. Best thing to do if buying locally is take the first chip with you. If not buying locally, have it with you when you order to make sure it matches.
Mar 29, 2008 | Toshiba Satellite P35-S605 Notebook
Ram
I've heard of this happening on several mainboards. It has to do with memory mapping. Have you tried flashing to the latest version BIOS?
Jan 11, 2008 | Biostar U8668 Motherboard
Intel Server Board S875WP1-E (S875WP1LX) Motherboard Logo
115 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
