Question about Innovage 1502084 Corded Phone
Area code I put in my local area code and when local calls come in, the local area code is included in the caller id. Therefore, when I push redial, the call won't go through because it's the same area code and I don't need to dial the area code. Then................. when a long distance call comes in, the 1- which preceeds the area code then the phone # isn't there. Then I have to redial the number myself putting in the 1. Who can help me with these problems? Otherwise, I love the phone.. Thanks..
I figured it out for my Panasonic KX-TG6581, at least. I pressed the soft key labeled "Select", then the one labeled "Edit", then pushed the Talk button and was able to return the call. It looks like a toggle setting -- I no longer see my local area code on the CIDs for local calls unless I repeat the above steps. It reappears after pushing "Edit".
Posted on Aug 05, 2013
    New Friend:
  • 127 Answers
I had the same problem with my phone. Tried a lot but couldnt fine the solution.
Posted on Feb 10, 2010
Phone adds #1 to local calls in caller ID
talk with your service provider
if the number 1 is placed before a local number then logically when calling that number, the number would be recognized as a local number and be charged as such
Form what you say , if the number was from a caller in a different state and the number was prefixed by say 6 then the system would recognize that as a long distance call
again talk with your service provider and if accurate contact your state governor or senator and make an issue of the law requiring the prefix number on caller id
Nov 21, 2017 | Panasonic KX-TG5439 5.8 GHz Dual Handset...
The caller ID screen is so faint I can't read it. Is there a way to brighten it or change the contrast so I can read it?
. Press and hold the dial/menu button until "Options Menu" is shown in the display.
2. Use the up/down buttons to scroll through the options below, and press the dial/menu
button to select the desired option you wish to set:
• Set Language
• Local Area Code
• Set Time/Date
• Set Flash Time
• LED Contrast
• Set Tone/Pulse
• Exit Options
3. Use the up/down buttons to adjust the setting, and press the dial/menu button to confirm
and set.
NOTE: It is important to set the Area code so that the telephone can distinguish local or long
distance calls when dialing from the Caller ID list.
NOTE: Time and Date will automatically set when you recieve the first or second Caller ID
Oct 16, 2012 | Emerson EM2646-WH Big Button Corded Phone...
When redialing a missed call how do I add the missing 1 before the area code? I have missplaced my user manual.
When you go to caller ID, move to the number you want to redial. Press *. The 1 will be added at the beginning of the number, then you can just press talk.
Jan 01, 2011 | Uniden DECT 6.0 Cordless Phone ID
The caller Id is only displaying the phone number without the area code and without the name. how can we fix this?
you may have the settings of your ViSYS to so that the phone knows the area code of the phone already.
If so, that will make the caller id display only the 7 digit local phone number. This is so you can easily call back that number, since most telephone exchanges don't require the area code before the phone number if the caller is in your local calling area.
Jun 10, 2010 | RCA ViSYS 2-Line Speakerphone
Area Code not showing on incoming calls. Sakar HT44ID-10
Not all systems require the area code. In fact if I am calling a number in my area from the ID caller & it has the area code shown, I must hit the pound key to erase the area code to make a connection. If it shows only the area code & it is a long distance call, I hit the star key to add a one in front of the existing number.
Aug 21, 2009 | Sakar Caller ID Telephone-White. Price...
Cannot redial from the cid list if the # shows an area code!
I have this same problem and am very unhappy with this system because of it. I've had Panisonic before and never have had this problem. I'd return the phones but it's been more than 2 weeks.
Feb 04, 2009 | Panasonic KX-TG1033S Cordless Phone
Does the Dect 6.0 recognize when a phone number needs a 1 before the area code (1-800-.......)?   I entered some numbers with the required 1, and some without it.  All the calls went through.   In a few...
If you save from caller ID to the phone book from an out of area code number, the manual doesn't tell you that you have press the * key while the number is displayed and it will insert a 1 before the area code. Do this before trying to call from caller ID or copying the number to the phone book. I had to delete the area code stored in the global set up to get the caller the "*" feature to work for my local calls other wise it would just put a 1 in before the 7 digit number and would not work when it is store.
Jan 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Shift 3 Talking Caller ID LCD Touch-Panel Phone
I have just purchased the Shift3 Talking Caller ID Phone. For some reason, the talking caller ID function does not work, i.e., no announcement is made identifying the number of the person calling. The "Set 8 Speech" is set "on". Any suggestions to getting this to work?
Jun 20, 2008 | Innovage Touch-panel Phone 1502084
Siemens 2520 gigaset base
You will need to customize your Call log settings to show which area code your located in so it will redial from the log properly. To do so, push Menu, then scroll to system settings, push select, then scroll to Area Codes, push select and specify the area code that you are in. If you need additional assistance, go to the link below which is the full manual on PDF, then go to page 48. Hope that helps. http://www.barclayent.com/manuals/Gigaset%202420%20Plus_guide.pdf
Mar 21, 2008 | Siemens Gigaset 2420 Cordless Phone
Caller ID
if you are putting 1 then the area code , just put in the area then the number and nt the 1 digit this should help
Feb 05, 2008 | Motorola Mobility RAZR V3
Innovage 1502084 Corded Phone Logo
288 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
Kolbrun...
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
