Question about Nikon Coolpix 5600 Digital Camera
Nikon coolpix 5600/4600 - won't turn on
I've had this digital camera for 2 years with no problems. Now it won't turn on. I've changed batteries (3 times) and they are alkaline batteries (not rechargeable). According to the Nikon Guide, these should work OK and they have for two years. Can you help resolve this or give me some other suggestions on what I can try? Thanks!
  • muftigal Aug 21, 2008
    Yeah, my camera won't turn on either. I've changed the memory and the batteries, but it's as useful as a brick at this point. I thought it may have been because the part holding the batteries in broke off (really poor design there), but I've duct taped it down and it still won't work. The light that turns on when you turn the camera on blinks on and off...but it doesn't do anything else.
I had the some problem... found a fix on another thread here on fixya...
hold the power button and at the same time press the play button.
Mine turned on after about 3-4 seconds of holding them down together!
Posted on Sep 09, 2008
    New Friend:
Just had this problem. Did as directed above and the camera did come on, but said "Battery Exhausted". Batteries tested good on two different battery testers, but the current needed to operate the camera was evidently not there. The batteries were Duracell MN1500. I usually use Energizer Industrial cells which never do this to me, but I ran out whilst in the field. Battery chemistry differs between manufacturers.
Posted on Jan 22, 2013
I was looking through some box's and i found this camera. i put in two regular AA batteries and it worked fine, now its not even turning on. I tried changing the batteries.
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Apr 13, 2015 | Kodak EASYSHARE Z1485 IS Digital Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
My canon powershot a495 has a problem. it always
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jul 04, 2011 | Canon PowerShot A495 Digital Camera
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
May 07, 2011 | Samsung TL 105 Digital Camera
Battery exhausted, change them, take one photo, and camera says battery exhausted again. I have this camera one year and this is the first time this has happened.
Good quality rechargeable batteries are a must for these cameras. What I would suggest is AA' NI-MH rechargeable batteries the type that come already charged and when used and recharged will hold their charge up to 80% for a year. These batteries you will find will outlast any AA Alkaline type. If you are using a no name department store AA Alkaline type battery it's a wonder it even turned on.
Dec 22, 2010 | Nikon COOLPIX L100 Digital Camera
I am in Pune 411004 in India and have purchased Samsung digital es 15 camera recently. Original 2 aa Alkaline batteries have been completely used up.when I replaced these with 2 new eveready batteries...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Cameras
Camera Won't Turn On
if your having battery problems then i suggest recharables...i got energizer AA rechargeable set and it works perfectly for me...hope this helps :D
Mar 25, 2008 | Samsung Digimax D53 Digital Camera
Epson 3100 life battery
I have a 3100z and you are right that alkaline batteries do not last long. The thing to do is buy a couple of sets of NiMH rechargable batteries and they last much longer. I,ve just been on holiday and had no problems at all with the batteries. (Although the camera does not give much warning when they need replacing).
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Nikon Coolpix 5600 Digital Camera Logo
601 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
