Question about Refrigerators
The freezer defrosted, and doesn't seem to be getting cold air. The refregerator appears to not getting cold air either.
    President:
  • 2,468 Answers
Replace the ptc overload relay on the compressor as it may sound like its running,but isnt,it merely unplugs and a new ptc plugs in place,it aids in compressor motor starting and running
Posted on Apr 10, 2011
Freezer stays frozen, but refrigerator doesn't stay cold
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Sep 13, 2011 | Magic Chef Refrigerators
The fridge side is not cooling well. It is cooler than room temp, but not cold. What could cause this problem?
In a side by side, the most likely failure for your type of problem is a failure in the drfrost ciruit (defrost heater, defrost thermostat and defrost timer) that allows an ice build up behind the inner back panel of the freezer. And then you also get an ice build up in the cooling tubes that is susposed to take cold air from the freezer compartment to the refregerator compartment.
The next likely item is the evaporator cooling fan that is located in the freezer compartment. If it is working then there is no cold air transfer. You should be able to feel the air flow in the refrigerator section if it is working.
Jul 22, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Bottom Freezer works well..But the top refregerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 12, 2011 | Amana Refrigerators
The refregerator will not cool below 45 degrees. the freezer is holding temp.
heatman101
Dec 21, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Freezer works but not the refregerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 24, 2010 | Samsung RS2556 Side by Side Refrigerator
NO COLD IN THE REFREGERATOR SIDE
heatman101
Oct 19, 2010 | Whirlpool GD5SHAX Side by Side...
Top refregerator not working
look for ice in back wall of freezer . this is a no frost and that means no frost .. you may have a defrost system failure .. mm
Jul 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ice forming in freezer refrigerator not getting cold
Replace your heater and thermostat behind the back wall of the freezer. the air will not flow from the freezer to the fridge because of all the forming ice. Also replace the defrost timer. take your model number into a local parts store and they can get you the parts. This is very common!!!!! But pretty easy to do.
Nov 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Bottom Freezer
This is the way it is supposed to work. Modern refregerators are designed to keep the freezer temp between 0 - 10 degrees. As long as it is not freezing food in the refrigerator compartment all is well. On most units the only real cooling control is in the refregerator. This is the one the cycles the compressor. The freezer control usually only controls the amount of cold air allowed into the fridge. All cooling coils are usually in the freezer. it just pushes cold air into the fridge
Jul 04, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
