Question about Microwave Ovens
I have a damixa aquaflow AF517 i want to know how canI install
MY KEYBOADS DOEN'T FUNCTION,WHAT CANI DO?
Depending of course on your full model number, you may need to replace the membrane keypad or the control panel frame assembly, which comes with a new keypad.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 26, 2012 | GE Profile : JVM3670BFBB 36" Over the...
Hi, we have a tapmate futura kitchen mixer tap that is constantly dripping. you used to be able to buy spare seal kits direct from the Berglen group in watford but seem to have disappeared any one out...
The suggestions above are rubbish. The problem is common with the Futura, because the spout is moved usually through 180 degrees. The kit consists of a plastic barrier washer, and o ring. Sometimes with the replacement grub screw. Tapmate was Berglen and Berglen was swallowed up by Damixa which in turn was taken by Bristan who have some spares but I don't know if they have this. Otherwise there is an overseas website for Damixa
Mar 08, 2011 | Microwave Ovens
What is watts for goldstar MA 1280M Microwave and if it is over 1100 watts cani i adjust it down
You can set it to different levels. It is doubtfull the magnetron will deliver more than 750 Watts as that is about all they can produce singley. Commercial ovens use at least two magnetrons.
Most specs on microwave ovens quote the power drawn not power produced.
I hope that helps.
Jan 01, 2011 | Goldstar MA-1280M Microwave Oven
I need to know how to linstall it as I lhave no
You can download the complete installation manual in PDF format from GE XL1800 support website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Jul 09, 2010 | GE XL1800 1100 Watts Microwave Oven
Need to know how to install
THERE IS EITHER OR BOTH A BRACKET THAT SHOULD BE SECURED TO THE WALL STUDS TO SUPPORT THE MICROWAVE AND THERE ARE THREE LONG SCREWS THAT GO THROUGH THE CABINET ABOVE THE MICROWAVE WITH AN OUTLET IN THE CABINET. THERE IS AN INSTALLATION GUIDELINE IN BOX. IF YOU STILL FEEL UNCOMFORTABLE HAVE YOUR SUPPLIER GET SOMEONE TO INSTALL.
Mar 10, 2010 | Kenmore 63252 Microwave Oven
INSTALLATION INSTRUCTIONS Want to know the proper height above the range to install it. thanks wayne
If the model number you have this question listed under is correct, your manual is available in a .pdf (Adobe) format that you can download or print for FREE. Just go to managemylife.com and type in your model number under the "Manuals" link. Then, narrow your search to the Installation Guide link. If you need further assistance, please let me know. I hope this helps you.
Jan 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Microwave Model 5200 - need plastic rotating ring
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
But it needs to be the full model number, not the partial you show in your post.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Jul 29, 2008 | Microwave Ovens
TRIM KIT INSTALL
Phone these guys at maytag - sorry info is not available online 1-800-688-9900. Hope this helps :)
Mar 09, 2007 | Maytag MMC5000 Microwave Oven
Microwave Ovens Logo
116 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
