Question about GE Microwave Ovens
I have a JVM140001 GE Spacemaker microwave (25 year old). The MOV has blown and I need to know what size to get as a replacement. Does anyone know?
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Ge spacemaker microwave
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in a bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit.
The parts kit is similar to this one: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MNfisherman
  • 11896 Answers
SOURCE: GE Spacemaker Microwave lights flicker on then off
There must be a short in the wiring between the bulb sockets and the power supply or control board. Otherwise the short may be in the bulb sockets themselves.
I would test the connections to make sure the wires aren't loose and all solder joints are tight. If all wires look good, and bulb sockets are tight, then the problem may be faulty capacitor
Posted on Jul 09, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: my handle broke on me ge microwave spacemaker xl
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Posted on Oct 11, 2009
PANEL LIGHT REPLACEMENT
Please remove the top cover to find the lamp mounted which can be replaced.
Click on: Bulb
Jan 24, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker (JVM1331) will not turn off when door is shut. Have had to unplug unit. This unit is 15 years old.
one or more door swiches need replacing maybe be three in all but likely one is the cause not sure which one without testing with electrical meter
Oct 21, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
How many cubic feet is a GE spacemaker model l# JVM240WL001
you must ask some vendor Online via chat with GE, they offer many Sales, and good opportunity. Get in tourch with them.
God bless you
Aug 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
My ge profile spacemaker II microwave went dark, no lights of any kind and no sound or response when pressing any button. tried resetting the circuit breaker but no change
Did you check the internal fuse? Often when everything is dark the fuse that protects the microwave is blown. Take the old fuse to your local hardware store and they will have a replacement for you. Should cost less than $5.
Nov 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Just wanted to know the size of the GE profile microwave model JVM1660BB005. Is it 1.5 cu ft? Looking at a new model JVM1540LNCS to replace it and want to use the same mounting hardware.
In GE microwaves, the first 2 digits of the model number are the cubic footage. 1660 is 1.6 cubic foot, 1540 is 1.5 cubic foot. Take care trying to use the existing hardware, the exact placement of hardware and upper installation screws may vary from year to year or model to model..
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker not heating
the magnatron has gone bad and maybe still under a warranty need to check with ge.if it is not then in most cases it is cheaper to go buy another microwave than to have it replaced.
Feb 23, 2010 | General Electric Microwave Oven
My spacemaker stopped working and no panel lights. It's not the circuit breaker. Any ideas? model JVM140001
Could be the fuse inside the microwave is blown. You will need to unplug the microwave and remove the front control panel. Inisde the microwave housing you will need to trace the electrical wire coming into the unit. Usually you will find the in-line fuse located on the black power wire. You can pull the connectors off the fuse and test it with a continuity tester. If the fuse is blown replace it but make sure you use the same amp rated fuse as you removed. If the fuse blows again then there is an electrical short somewhere in the microwave.
Dec 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Spacemaker Fuse Blown
its either a 10-15-or20 ceramic fuse and its marked on the side of the fuse or take it to the hardware store they have this type of special fuse.and they can locate the rating for you
Oct 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
234 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
