Question about Kenmore HE3T Washer
I am getting an F05 code and then the machine stops and pumps all the water out at the beginning of the cycle. i have a kenmore elite he3t machine. thanks
  • 1 more comment
  • ebrand97 Apr 10, 2011
    where is this sensor,can i get to it by taking the bottom front panel off or is it in the back of the machine?
    i have the top and the bottom panels off but i do not see a temp sensor or a heating element all i see is a solenoid on the cold and hot water to let the water in, where do i look for this sensor and heating element?
  • Kenmore Master
  • 2,605 Answers
welcome to FixYa.
The place to begin would be indeed at the sensor, and then check the heating element and connections. In my experience though most times it is simply a wire has become loose or broken since these things vibrate so aggressively throughout a cycle.
**Unplug the unit from the wall before performing any service suggested here unless otherwise stated...some service requires voltage supply but safety first**
If you remove the access panel from your washer in the front, it is held in place by three torx head screws, size T20 you should find a tech sheet on the right hand wall...from front, or taped to the inside of the service/access panel you removed.
i.e.
The heater and sensor are located at the front of the outer tub on most of the HE3 machines as shown below...the image here does not have a heater, but some do some don't ( if you can provide a complete model number I could speak to your machine specifically )
Once you've visually inspected the sensor and wires and heater ( if applicable) you'll need to verify the components themselves are good.
Let me know how you make out to this stage and I'll help you move forward from here if still necessary. Good luck.
Thank you for choosing FixYa today.
Regards,
Macmarkus :)
Posted on Apr 10, 2011
  • Kenmore Master
  • 7,482 Answers
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
i am getting an F05 code and then the machine - globul1a.gif Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
I have a Kenmore elite he3t washer. It flashes f5 at the beginning of a cycle
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Feb 04, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Eric
Sep 17, 2009 | Washing Machines
Kenmore elite washing machine spin cycle slow. The clothes are still dripping wet when removed from the washer.
In my HE3T, this was indicative of the water pump going out. In its 8th year, my HE3T is now on its 3rd water pump.
Aug 02, 2009 | Kenmore Washing Machines
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t code problem
check your water supply make sure that you have both hot and cold water on at all times. Pull the hoses off and see if the screens on the water valve in the back is clogged.
Aug 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t
Here's a link that explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Read through these steps and let me know if you require further assistance. HINT: I'm assuming you have water entering the wash tub since you mentioned the washer will begin a wash cycle. Check for a siphoning issue or Drain Pump problem first. These are the simplest items to check. I hope this helps you.
PS There should be a tech sheet located inside you washer behind the lower panel under the door, or along the interior cabinet wall that explains all the error codes and how to troubleshoot. This may also assist you further.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3T Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
