Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F&P DD605SS dishwaser F1 FAULT
Hi, I have a flooding fault on my F&P DD605SS Dishwasher. It has occured before due to "overlaoding" of unit. It has occured again( unit was not overloaded) I know how to to dry the board out ect ect as the service guy showed me how to do it,but the service guy also punched in a lot of codes into the front panels...Do i need these codes to get the unit to operate properly??
Thanks,
  • Anonymous Oct 01, 2008
    F1 fault on both drawers. does not reset when power turned off
  • Anonymous Nov 06, 2008
    how do i clear f1 code? accidently put dishwash soap instead of dishwasher soap......... came back from beach and it was flsahing f1 code!?!?!??? wouldnt reset with power turn off how do i fix??? any help
  • 144 Answers
You don't need any codes if you've dried out the base and it's still not going I can talk you through finding the fault in live chat. cheers
Posted on Mar 27, 2009
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
F1 has come up
This video explains how to repair this issue
Feb 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I am getting a F 1 code on my dishwaser. I hit power to shutt off but it just comes back on and blinks F 1
This video will aid you in you F&P dishwasher repair.
http://www.appliancerepairlesson.com
Feb 09, 2011 | Fisher and Paykel 23 in. DD603H SS...
Error Mesage F1 beeping does not operate
The reason for F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorized service center. These problems cant be fixed on your own.
Thank you !!
Aug 02, 2010 | Fisher and Paykel Dishwashers
F1 error
Thank you !!
Jul 12, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Eletronic oanel displays F1
Thank you !!
Jun 21, 2010 | Fisher and Paykel DS603SS Stainless Steel...
I have a single draw Fisher and Paykel dishwasher. I stupidly put washing up liquid in the dishwasher which resulted in a F1 problem. Water started leaking under the draw and onto my floor. I turned the...
ok , F1 means your flood switch has activated, which is underneath the drawer. now they show the F1 fault because of 2 reasons.1st there is still water underneath drawer causing switch to activate. 2nd your activator board which has the flood switch attached is faulty reading your posting it has been about 15 days since the fault happened. the water should have dryed around switch by now. if there is power to the unit and it is still coming up with F1 fault then possibly you have damaged the activator board. please reply and tell me if you have power on or off at the present time. to fix the problem it is alittle bit involved but i can guide you thru it when you reply .good luck
Apr 23, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 fault on a ds603
The reason for your F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorised service centre. These problems cant be fixed on your own.
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 display flashing?
Flashing wrench means a fault code has been triggered.
F1 is the fault code when flood switch at base of dishwasher cabinet turns on.
This can occur due to several reasons when moisture gets to the base of the drawer cabinet.
You will have to turn the power off and extend the drawer out as much as possible to expose the back of the cabinet. Take towels and a hair dryer to dry the base. Once the flood switch gets dry the problem will go away.
The main thing is why did the water get there. You could have a crack in the hose or simply the detergent may have caused too much foam.
Jan 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 flood fault.
fi code comes up.....what do i do????
Aug 05, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
122 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
