Question about Husqvarna Garden
I have a Husqvarna YTH20F42T and it loses power when I push the gas pedal all the way down and also reverse is very slow. I have changed the oil, air filter, fuel filter, spark plug, drive belt, and deck belt. The mower works fine on a level surface with the pedal pushed half way but will not speed up when pushed all the way down.
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Posted on Apr 22, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 44 Answers
SOURCE: 48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Posted on Jul 21, 2009
  • 95 Answers
SOURCE: How do I adjust the deck level on a Husqvarna
Not sure if you are looking for the nuts and knobs or how to level? Most newer decks have knobs for adjuctments. I park my mower on a concrete level surface make sure all tires are at the correct psi then with tape measure check front left and right at bottom of deck for same measurment. You can also put a 2 ft level on the deck and adjust.
Posted on Mar 13, 2010
1992 olds cutlass supreme wont accelerate when pushing the gas pedal
Check oil first, Low oil sensor will shut down if more than a quart low. Change fuel filter, could be fuel starvation, change the air filter. stopped up air filter will put MAF sensor out of range. PERFORM OBDII SCAN SOON.
May 19, 2017 | 1992 Oldsmobile Cutlass Supreme
My Husqvarna Rider 16c wont reverse - first it was slow in reverse then not at all
You need to check the cable, it is a push pull telescopic style so it is possible to get forward and no reverse, if it was a hydro problem you would not get forward or reverse, there is also timing gears on the forward and reverse pedal, you nee to make sure they have not jumped a tooth as this would reduce movement on the cable at the hydro
Feb 12, 2013 | Husqvarna Garden
Why does my 1993 oldsmobile bravada bogg down an die when i press the gas down
bogging down no power
part of the efi system failing
fuel
spark plugs
timing
automatic tranny
check oil level
if it was a sensor or shift solenoid
the check engine light would be on
Mar 20, 2017 | 1993 Oldsmobile Bravada
Reverse has got real slow, forward is slowing down to.
yea i know i did the trick i bought 2554 huq i have a lever shift i cut the platic on the reverse tp make it longer and it go much faster. now for floor pedal need make a bracket higher on pedal should make go down further and faster too.
Jul 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 450, and I would like to increase my bar oil output. Where is the adjustment screw? Please!
There is no adjuster for the Husqvarna 450. Husqvarna recommend that if there's not enough oil reaching the bar that you slow down the engine by adjusting the carburettor screw. I have the same saw and also wanted to adjust the oil flow. I didn't change the carburettor and it's still cutting away without doing any damage. It's meant to use less than a tank full of oil to the tank full of fuel when you're cutting near constantly. With stops in between it will use more fuel and less oil.
Nov 08, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
2000 olds Silhouette I have tired reseting the oil change reminder, by pushing down the gas pedel three time. I have tried going slow and fast. It won't reset. any ideas?
precedure:
1. turn ign key to "ON" (engine off)
2. push accelerator pedal fully to the floor and slowely release 3 times within 5 seconds
3. turn ign off
4. start light should be off
Feb 04, 2010 | 2000 Oldsmobile Silhouette
Engine light flashes
it is the catalist that is obstructed,the stone is broken inside,by temp it fails to let enough air through,
or replace,or open,break out one part for better air stream and weld closed again,
Feb 13, 2009 | 2002 Volkswagen Passat
Car loses power with check engine light on
get a code # scanned from the computer and we'll try and help further. could be mass airflow sensor or fuel pump
Nov 22, 2008 | 2005 Chevrolet Cavalier
Garden Logo
110 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
