How do you remove the soap dispenser to clean it
    Brigadier General:
  • 6,277 Answers
You do not say which model it is but these are designed to cover most!
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
Good luck,
John C
Posted on Apr 11, 2011
3 Suggested Answers
abhishek33
  • 1239 Answers
SOURCE: Removal of washing machine soap dispenser - Indesit
hi
When you wash very linty materials, remove lint from the tub after removing the laundry. Soap deposits may cause laundry to smell bad. To solve this problem, fill the tub with water and add 1 pound of water softener or 1 gallon of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach. Caution: Rinse the tub thoroughly before wiping it out with bleach. Ammonia and bleach can combine to form a very dangerous gas. Finally, run the machine through a complete wash cycle before you put any more laundry in.
Posted on Sep 13, 2008
richroth
  • 9472 Answers
SOURCE: The fabric softener (downy) won't dispense. It
You will also need to clean the the dispenser hose that goes into the machine.
Posted on Jan 21, 2011
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
Fix soap dispenser
remove the entire soap dispenser and clean out any dried soap which may be lodged in the pick up tube, blocking the pump
Aug 26, 2014 | Plumbing
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
My soap dispenser does not clean out. ie fabric softener compartment does not rinse all of the fabric solution out.
Hi, remove the dispenser draw and clean out, you'll probably find a load of unused soap and softener gunked up in it
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FQ106D1 Main washsoap dispenser always has soap in
remove dispenser drawer and give it a good clean.adrian,,,,
Jun 14, 2010 | Washing Machines
Soap dispenser not working properly, the fabric softener and the liquid bleach not dispensing properly. Sometimes the softener dispensed as soon as I push start. The bleach not dispensing at all I have...
Don't know where you live, but commonly silt comes up with the cold water supply, especially in rural areas, and clogs the holes in the dispenser. The best way to deal with this is an old toothbrush to rub it clean. When it dispenses some bits too soon, it could be that the water is pushing through the only holes that are available. Give it a good scrub with an old toothbrush and hopefully you will both be smiling :)
Jun 20, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Soap dispenser doesn't work- Price Pfisher Marielle 950-009S
mabe the straw it self is blocked , try to clean out the inside of the straw and the head part and let me know if that dosent help and ill brain storm some more
Jun 05, 2010 | Price Pfister 950-009S Marielle Soap...
He4t dispenser problem soap
Remove the soap tray and clean the orifice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
