My Easi Logic 1600 cuts out 20 minutes before cycle ends and will not drain & spin on spin cycle.
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 11, 2011
My GE HE top load washer quit draining & spinning. I*t went through a wash cycle just fine. It drained & spun for that, but at the end of the rinse cycle it wouldn't. I even tried to put it on
WE HAD THE SAME PROBLEM. ONLY OURS WOULDN'T WORK ON THE "WHITES" CYCLE BUT WOULD WORK ON THE OTHERS. BUT IT WAS JUST A MATTER OF TIME BEFORE THEY WOULD ALL GO & THE REPAIRS WOULD BE $$$. YOU WILL EITHER NEED A REPAIRMAN & YOU'RE LOOKING AT A MINIMUM OF $200........IF YOU'RE LUCKY. DO YOURSELF A FAVOR & GET THE G.E. MODEL #GTWN2800DWW AT HOME DEPOT. LOOK AT IT IN THE STORE BUT BUY IT ON LINE (AS THERE MAY BE A $50 DISCOUNT). THIS WASHER IS WHAT YOU WANT. YOU WON'T BE SORRY.
Jan 11, 2015 | GE Washing Machines
Servis easi logic 1000 is filling up then half emptying then turning off
Have you just moved the washer to it's present spot? if so maybe the drain hose is to low and the water is siphoning out. Something may also be wrong with the pressure switch.
Dec 29, 2014 | Washing Machines
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
When my washer gets to the spin/drain cycle (the last 20 minutes) it cuts off and unlocks. The machine keeps locking and unlocking and that's it. It will not move to the spin/drain cycle. What is the...
The filter on the front side of the washer was clogged. I have two children. So, I found candy wrappers, lip gloss, pennies. After cleaning the filter, it runs fine now.
Dec 17, 2009 | General Electric WCVH6800J Front Load...
Indesit Evolution 1600 WE 16 Washing Machine with F 05 Display
Get unit to spin and drain. See if any of those are a problem. Check if heating element has a circuit and if possibly an over temp cut out has occured. Normally if a code no. has come up, a certain condition has occured which should be rectified.
Sep 16, 2009 | Washing Machines
My servis easi logic 1400 doesnt switch over in cycle.
Check the control card for dry joints. This is a common problem with these machines
Jul 04, 2009 | Washing Machines
Servis Easi Logic 1500(M6050) Washing Machine doesn't wash & spin
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 19, 2009 | Washing Machines
Washing machine cuts out when reaches spin cycle
It appears your motor/motor controller has failed in this instance.
Mar 02, 2009 | Kenmore 22422 Top Load Washer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
