Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Have 839 mcculloch new plug/petrol /plus oil ,wont start .any ideas.thanks
Editor925
  • 285 Answers
SOURCE: need to know the correct levels of oils in a chainsaw
Most McCulloch saws use a 40:1 oil ratio if using McCulloch branded 2-stroke oil. They state 20:1 for other oils, but this is probably overkill as most name branded 2-stroke oils these days are pretty good. I would probably go for a 30:1 or 35:1 mix to err on the side of caution. This will not affect performance, it may just mean you need to change spark plugs a little earlier than usual, but the cylinders will at least be well lubricated.
Please rate my response on FixYa.
Posted on Mar 25, 2009
  • 11 Answers
SOURCE: petrol to oil ratio McCULLOCH 55cc chain saw 2 stroke
25 to 1
Posted on Apr 07, 2009
Curt_W
  • 60 Answers
SOURCE: Trying to get McCulloch MS354 35cc chainsaw started
Stiff usually means good compression. So, pump the fuel bulb, put your foot on the flat in the handle, lock the throttle open using the button on top, set choke all the way out and pull. It should kick after a few pulls. Then close choke half way, and pull until it starts, then push choke all in. If it doesn't start, disconnect spark plug and take it out. Have someone watch while the sparkplug is held against metal engine to see if there is a good spark at the plug. If not maybe needs new coil. look at plug to see if it is wet, ie, gas is getting to it to isolate problem to carburetor.
Posted on Apr 27, 2009
  • 76 Answers
SOURCE: please advise oil/petrol ratio...air gap ...plug
Hi
follow the link there are several manuals there for Echo chain saws
http://lawnandgarden.owneriq.net/manuals/mfg/echo/echo_chainsaw_product_list.html
http://www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
on page 4 it says the types of oil and petrol
hope it helps
appreciate some rating form you.
thanks
Posted on Jul 18, 2009
  • 152 Answers
SOURCE: i have a mcculloch 484 chainsaw 16 inch blade.what
50:1.... gas to oil
Posted on Dec 06, 2009
Oil to petrol ratio
25 to 1 get 2 stroke oil from a hire shop only need a one shot mix, will do up to a gallon.
May 02, 2012 | Mcculloch 16" Electric Chain Saw Mcc3516f
How critical is the oil/petrol mix ratio in terms of starting and maintaining engine running for a McCulloch 2 stroke chain saw?
All the lubrication for the engine comes from the oil mixed with the fuel, so it is VERY important that you use good quaility two stroke oil designed to be used in a chainsaw, and mixed as per the manufacturers recommendations, if you are not too sure then run a 25.1 fuel oil mix, if the egine lacks lubrication the piston will start to scuff around the exhaust port ( the hottest part of the engine ) lose compression and become difficult or impossible to start. A quick check is to remove the muffler and take a look at the piston skirt through the open exhaust port.
Mar 06, 2012 | McCulloch Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Ratio of oil to petrol for a McCulloch Trimmac 240
normal mix for pet/oil is 50:1 but it depends on the oil you use
Jul 11, 2010 | McCulloch Trimmer Plus Attachment: Add On...
Mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Jul 04, 2010 | Garden
Mcculloch 738 mixture adjustment? It starts ok but after a few minutes it stops working and wont start again for several hours, presumably when it is cold. Any ideas. # Thanks mcculloch 738 petrol...
You may have fuel vent problems--remove the fuel cap, then replace it and try to restart the engine. If runs for a while again, probable vent blockage. If this makes no difference, remove the spark plug and check for snappy, blue spark. If nothing or very weak, try a new plug first. If still nothing, then probable ignition module failure when hot. Use a thin business card for a pole gap and turn the flywheel magnets under the module. Allow to stick to the magnets then tighten the mounting screws. Rotate the flywheel to remove the card, then rotate it one full turn to make sure the gap doesn't close up at any point. Mixture adjustment doesn't seem to be called for here. Make sure the engine is not overheating due to sawdust accumulation. Hope some of this helps!
Jun 13, 2010 | Garden
My mcculloch petrol hedgetrimmer wont start, the pull cord has a lot of resistance. I have changed the spark plug and cleaned the air filter but still no joy.Interestingly When i remove the spark plug i...
The fact that your engine turns over easily with the spark plug removed simply means that, with the plug removed, there is no compression, so the piston goes up and down very easily.
If it has been a while since you ran the machine, and if you left gas in it, your carb may have gotten gummed up from the gas losing it viability and turning to something like varnish. You might try spraying carb cleaner into the carb (with the air filter removed), let it sit for a few minutes, then try starting. In the future, you probably should get some fuel stablizer (available at almost any hardware store) and add it to the fuel that you use for your small machines. It will keep the gas viable for a much longer period of time.
Hope that you are lucky enough that the carb cleaner, a good dose, will work. If not, you may have to disassemble and clean out your carb. (if you've never done that, a series of digital camera photos so you know where to put things back is a good idea).
Oct 18, 2009 | McCulloch Garden
Brand new Husqvarna R53SV 53cm Petrol Mower wont start. We put petrol and oil in it. Connected the spark plug put the choke to on, Pulled the starter string. Nothing happend. After trying a few times you...
Buy some starting fluid and spray some in the carb or air cleaner intake port, if the machine is flooding do not choke while using the starting fluid, make sure you do not have too much oil in the mowwer.
Jul 15, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Need to know the correct levels of oils in a chainsaw
Mar 24, 2009 | McCulloch Garden
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
80 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
