Question about LG RU-42PX11 42 in. EDTV-Ready Plasma Television
NON SI ACCENDE LO SCHERMO E NON SI VEDE NIENTE?LG RZ-42PX11
3 Suggested Answers
SOURCE: LG RZ-42PX11 42
Common problem. See this site -
http://www.forums.hcsd.com.au/Blah.pl?v-print/m-1175589480/
Posted on Jul 09, 2008
  • 325 Answers
SOURCE: Sky TV REMOTE WILL NOT WORK MY LG tv RZ 37LZ55
Hello Kenny
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
Cheers
Little Dish Fitter
Posted on Sep 29, 2009
Bande verticali colorate
Check its back-light inverter board and back-light CCFL lamps. In most cases, lamps found faulty. Check and replace the faulty ones. If you wish to get more details, check this site.
Feb 11, 2013 | LG 26LG30 26 in. LCD TV
Non accende
Please RUN the software calibration for easy diagnose, troubleshooting and fix it.
God bless you
May 16, 2012 | Exercise & Fitness
Il mio Acer T180 non da più segni di vita nel senso che, collegando il cavo di alimentazione, non si gira nessuna ventola e non si accende nessuna spia L'unica prova che ho fatto è...
Sembra che il vostro alimentatore pu? essere morto, perdona il mio italiano, anche la if alimentazione non si accende non mean it effettivamente funziona, prima di cambiare la tensione, provare questo, scollegare il system, rimuovere la scheda madre battery, tenere premuto il potere pulsante per 30 secondi, rilasciare,, sostituire la batteria, plug-in e si accende,,, se quello non riesce, individuare i pin sulla scheda madre che il pulsante dell'alimentazione si collega anche, ci dovrebbe essere qualche altra cosa l? come bene, come reset, LED di alimentazione e HD LED, assicurarsi che il sistema ? collegato a sua volta e lo ob utilizzando un cacciavite tipo di lama e bridiging entrambi i perni di alimentazione con esso. I apoligise ma non sono molto bravo a itallian Quindi, se ho mescolato tutto mi perdoni ..
Sep 16, 2010 | Acer Aspireā„¢ T180 PC Desktop
Si accende e poi dopo un po si spegne, per apparire l'immagine devo riaccenderlo e poi subito dopo si spegne
try to remove any power saver settings from the screen savers position in the properties of the desktop...For that right click on the desktop ..choose properties..than screen saver and in the power are on the bottom of the page ..set all to never turn off...
provi a rimuovere qualunque regolazioni del risparmiatore di alimentazione dalla posizione dei risparmiatori dello schermo nelle proprietà del desktop… per quella destra di scatto sul tavolo. il risparmiatore dello schermo delle proprietà. .than di .choose e nell'alimentazione è sulla parte inferiore della pagina. .set tutti da non spegnere mai…
Jun 28, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
OSD IS LOCKED AND WILL NOT UNLOCK! MODEL IS .....HANNSG HU196D
hey, to unlock osd press and hold the volume down "<" the volume up ">" and "menu" all at once then the osd will unlock
May 27, 2009 | Hanns.G Corporation HU196D (Black, Silver)...
Non si vede niente dal monitor
tre bip lunghi potrebbe essere un problema della tastiera.
Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco.
* Un bip = tutto funziona normalmente.
* Due bip = errore POST/CMOS.
* Un bip lungo ed uno breve = problema con la scheda madre.
* Un bip lungo e due brevi = problema video.
* Un bip lungo e tre brevi = problema video.
* Tre bip lunghi = errore tastiera.
* Lunghi bip ripetuti = errore di memoria.
* Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre.
* Continui alti e bassi bip = surriscaldamento CPU.
guarda anche questo sito
http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
Dec 31, 2008 | Intel D945GCCR Motherboard
Open Questions:
See all LG RU-42PX11 42 in. EDTV-Ready Plasma Television Questions
LG RU-42PX11 42 in. EDTV-Ready Plasma Television Logo
96 people viewed this question
