Question about Saeco Caffe Charisma Espresso Machine
Saeco charisma will not prime. pump runs when turing steam/water knob but no water delivered out of steam tube
  • bahamabob Aug 10, 2008
    Worked like a charm. Have great espresso's now . THANKS
  • 515 Answers
Try to take a bellow pump or similary and force in water in the water inlet, make sure you have the steam knob open when you do this.
Posted on Aug 09, 2008
Hi, I a problem with my Saeco s-class incanto classic coffee machine. The two coffee cup lights are flashing green the water light is flashing red. I prime by turning the steam valve and hardly any water...
Try this, when you run the hot water cycle to prime machine and it stops putting out water push in on the knob if that works then replace the tap rod assembly or the whole steam valve assembly.
Aug 29, 2010 | Saeco Incanto Classic Espresso Machine
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
Water leaks from bottom of Saeco Caffe Charisma when brewing
Remove brew chamber, check the back of the white plastic valve make sure the chamber under it is clear of coffee grounds and water, then check the red o-ring on the brew chamber make sure there are no cracks or damaged spots.
Jul 15, 2009 | Saeco Caffe Charisma Espresso Machine
Not pumping waer but making hella noise
Hi
Needs to be primed. If you open the steam knob and and you don't get water out, the pump has lost its prime. Check that you hose is in the tank, or has become disconnected inside.
Jun 20, 2009 | Saeco VIA Venezia
Saeco via venezia coffee machine wont prime
Turn machine on and make sure that the knob is fully opened, if the pump does not engage(vibrate) then either the machine is not getting power or there is a problem with the pump.
Apr 19, 2009 | Saeco VIA Venezia
Unable to get water to pump in order to prime
Aug 09, 2008 | Saeco Caffe Charisma Espresso Machine
Machine will not prime????
I think you have to replace the flow meter (water turbin), it´s like a water counter.
Jul 19, 2008 | Saeco Caffe Charisma Espresso Machine
No instruction on how to prime a saeco caffe charisma machine. looked in the book that came with it but there is no instructions for this process
Prime = letting some water out from the water/steam nozzle. Priming means that the machine has not water in the lines. By letting water come out, you are making sure that water fills all the components and is ready to use.
Apr 28, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Caffe Charisma lights do not stop flashing
I had the this same issue and made a post to this thread, in that post I had this solution to my conditions.
The combination of actions that seem to work was turning the Saeco on while the steam valve was already open and selecting hot water once the Saeco was powered on. The prime light went out, I closed the steam valve
Jan 31, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Caffe Charisma Espresso Machine Logo
189 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
