Question about Sharp Televison & Video
Tenho tv sharp aquos modelo LC-40AE7 qebro la pantalla cuanto cuesta mais o menos la reparacion
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 73 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Sep 27, 2009
  • 8457 Answers
SOURCE: Sharp aquos LC-42D62U. Have audio but no picture.
Ur LCD inverter is dead,must replaced to get the picture back.
Posted on Dec 02, 2009
budmrtn
  • 11361 Answers
SOURCE: ME PUEDEN INFORMAR DONDE COMSEGUIR LA PC POWER
Diagram will be impossible to get.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Posted on Aug 13, 2010
SOURCE: PANTALLA LED PRECIOS 42 ".
se me rompio la pantalla el es crim
Posted on Feb 18, 2011
Tengo un telefono daewoo adp 2200 duo y uno de los terminales me pone sin reg en la pantalla sin dejarme hacer nada y aparte se me ha bloqueado, alguien me puede echar un cable, gracias
sugiero que lo lleve al taller de reparacion. Es muy dificil instruirle como hacer algo, pues no se trata de software sino de Hardware, a menos que usted tenga mucha habilidad en electronica digital avanzada, para hacer reparaciones delicadascon telefonos sofisticados.
Dios le bendiga.
May 10, 2012 | Televison & Video
Se me rompio la pamtalla de un lcd 32" LG COMO HAO CUANTO ME CUSTA S PUEDE O NOOOOOOOOO GRACIAS
Disculpa mi pantaya sanyo modelo dp32649 se estreyo la pantaya del lado derecho si se ve el izquierdo y el audio tamb funciona tiene reparacion o como le pdo aser grax
Jan 22, 2011 | Televison & Video
DONDE PUEDO COMPRA UNA PANTALLA, YA QUE SE ROMPIO.
la puede comprar the esta destribuidora www.encompassparts.com , le cuesta entre $200 a $350 dependiendo de la vercion del tv
Jan 03, 2011 | Emerson LC195EMX 19 in. TV
I can't find ACER TV info on the web. I'm after
tenho problema de localidade numa tv led comprada na europa modelo AT2058ML que não aceita antenas do Brasil. Gostaria de saber como configurá-la, porque o menu na antena pede outros e código do Brasil, mas não sei como configurá-lo.
Sem mais,
Neori Paim
May 15, 2010 | Acer AT3705-MGW 37 in. LCD Television
Necesito reemplazar la lampara (SHP70 HG) de un televisor de retroproyeccion akai modelo PT46DL10 quisiera saber su precio forema de pago y el tiempo de entrega enviar respuesta a: diol671002@hotmail.com...
Este website solo te da información para resolver tu problema. No te vende la lámpara que cuesta al menos 120dlls y la encuentras fácilmente por internet.
May 17, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Tarjeta madre
Haz busqueda con el modelo y la marca que usas en ebay.com, hay muchos vendedores que despachan a todas partes del mundo.
No sae si sabes ingles pero en el espacio de busqueda(Search) tipea la marca por ejemplo Asus y el modelo AB-12345. Escoje la opcion BUY NOW cuando obtengas los resultados para evitar concursar en la subasta y saber inmediatamente cuanto cuesta.
Apr 09, 2010 | Gateway GT5220 PC Desktop
No enciende y me dijeron que entro agua posiblemente y esta mal la tarjeta madre quisiera saber cuanto cuesta.
busque en alguna tienda local o vea si puede conseguir alguna notebook que sea el mismo modelo, pero que no funcione. Reparar notebooks generalment no es muy convenient, ya que es muy caro comprar las partes de reemplazo
Mar 13, 2010 | Acer Aspire 5315 Notebook
NECESITO UN CD ROOM DE UN QUICKLINK PEN MODELO QL 1000
MIra a este link: aqui o aqui o aqui
Yo espero que este es de ayuda.
Lo siento, pero yo no hablo mucho de espanol...
Jun 19, 2009 | Wizcom Quicklink Pen Handheld Scanner
Televison & Video Logo
27 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
