Question about Car Audio & Video
Radio comes on but keeps bleeping - Car Audio & Video
  • 4,861 Answers
This looks as though it might be a VIN coded radio
Is it a new or replacement one?
If so then it has to be electronically linked to your car. A job for the Main Dealer or a Radio Decoding Service.
If not, then it might just require a code.
Post again if you do not have the code
Posted on Apr 10, 2011
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Cd player plays but has a loud bleep
Sounds like it needs recoding. Try entering the radio code, if you don't have it, your Citroen dealer may be able to help.
Oct 09, 2012 | Car Audio & Video
At switchon the mother board bleeps continously for about 10 secs takes a break 5 secs then goes bleep again for another 10 secs and repeats the cycle reapetedly until switch off. All drives have been...
It is a very real possibility as there are no beeps when it is removed, but that does not mean it is faulty, you could be getting POST beeps suggesting there is a fault with the mainboard, have it checked out with a local & reliable engineer who may be able to solve your problem.
Keith.
Aug 06, 2017 | Intel Server Board SE7501CW2 Motherboard
We have a PS3, a few years old, never had a problem. My son turned it on tonight and the initial "PS3" logo comes up with the wavy line and then thats it. Just keeps the wavy line there...
hello, turn the power on then press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset the ps3
fingers crossed it should work
regards
shaun
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
My fridge will not stop bleeping and keep showing that the door is open but its not the bleeping keeps coming and going
may be the door ajar switch is not working or is jammed. Just look at the edge of the door that is hinged. You will find a switch which is pressed when the door is closed. Just manually press and release it few times. If things do not change, call a technician
Apr 01, 2010 | Refrigerators
I have a Clarion car radio model PU2294A(C). Lost
The beep is because the radio is still waiting the correct code.
the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also  has a BARCODE SERIAL NUMBER beginning with C7000000 + + + +  on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
There is a 20% chance of you having this barcode Serial Number
If not then it will only be available from  your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
If you DO have this Barcode Serial Number , then
POST A NEW QUESTION
requesting the code
Nov 03, 2009 | Car Audio & Video
Peugeot car radio gives loud bleeps when playing
there is an circuitary prob contact an engineer
Oct 01, 2009 | Car Audio & Video
Renault scenic radio code
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [¬ ] button then rotate the thumb wheel for the correct third digit
Press the [¬ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
May 04, 2009 | 2000 Renault 181
Want to disconnect the bleep altogether on my cobra 148 gtldx
If this is a stock cobra 148 gtl 40 channel am plus side band, they don't to my knowledge come with a built in r beep. Some roger beeps are instaleed through the transmit circuit on the mic, so if not in the know Don't try to fix it.Some microphones have a beep built in. I used to install beeps on these radios using the pa/cb switch to turn them on. also try the nb switch or the swr/rf switch.
Feb 04, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
