Question about Goldstar DH504EL Dehumidifier
AFTER A YEAR MY DEHUMIDIFIER WONT TURN ON, IS THERE A FUSE HIDDEN SOMEWHERE IN THE UNIT THAT COULD POSSIBLY BE BLOWN? IF SO MNCOULD YOU POINT ME IN THER DIECTION TO REPLACE IT. THANK YOU
  • scott_mcalee Apr 12, 2011
    i dont use the bucket, i direct drain into a drain in the floor, would this bucket switch still be the cause. thank you for all help
    President:
  • 2,468 Answers
Its the bucket switch on the unit thats bad,it controls the water level overflow so unit shuts off when bucket is full,its at the top rigt side of the bucket mounted to the float in the bucket and there is a replacement available part # AP3136674,on some units depending on the mounting hole size,you may need to use some old switch mounting parts on the new switch so it fits
Posted on Apr 10, 2011
Testimonial: "very helpful . i left out some info that may have been relevant in the diagnosis so i hope i get a return message. fast and very helpful, thankyou"
  • danny Hendrickson Apr 16, 2011
    still,please try bypassing the bucket switch as this seems to be a large percentage of these units shut down problems,this switch is in series with the whole unit on the power supply side cord and carries all current the unit requires to operate, even the fan
    if this doesn't help you,there also is a small black round disc mounted on the circuit board which is a one time fuse,you can remove the wire harness from the circuit board to do a positive fuse test,but still try the bucket switch first as its easier to get at
It wont turn on at all? is there a fuse in it that can be replaced?
If there is a fuse then it's blown for a reason.
You do know there has been a recall on some 30 pint dehumidifiers? How old is yours?
Jun 24, 2014 | GE 30 Pint Portable Dehumidifier
Never no water in dehumdidifer to empty
I'd suggest you (1) make sure dehumifier is plugged in, (2) the circuit it's connected to is live (breaker not tripped and fuse not blown - this is easily tested by plugging in an appliance (e.g., hair dryer) you know works). If the unit turns on, it is likely defective - unless there is a hose connected to the dehumidifier that reroutes the water removed from the air to a drain (is there moisture collecting somewhere within 6-10' of the unit?). If it doesn't turn on, and you've troubleshooted the above to ensure there is electricity to the receptacle, then it's either defective or the moisture setting for removal needs to be adjusted for the humidity in your basement. Perhaps it's dryer down there than you thought, or your hygrostat (? - whatever the doohickey is called that senses humidity level) is set at too high a level that it never turns on/trips in your area. Hope it helps.
Jul 31, 2012 | Haier 30 Pint Dehumidifier
No lights or sound...changed outlets just stopped running, is there a fuse that could be blown?? or ???
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 13, 2010 | Haier HDN455 Dehumidifier
Amana d545m dehumidifier no power
replace 24 volt 1 watt zener diode on circuit board. 1n4749 (nte5081a)
mine was hit by lightning and this fixed it.
Jun 23, 2009 | Amana D545M Dehumidifier
Where can I find the fuse on the panel?
tiewraps.com on the internet, you can purchase a 10 pack of 250volt 12amp fuses. AG-12
Jul 14, 2008 | Haier HDN655E Dehumidifier
No Power
Found the fuse at this website www.tiewraps.com ORder the AG-12
Jun 27, 2008 | Haier HDN655E Dehumidifier
Blown Fuse on Compressor of Dehumidifier
That part is a thermal protector. If you can't find it at Radio Shack they should be able to direct you to an appropriate electronics store.
May 19, 2008 | Maytag M3DH30B2A Dehumidifier
LG 65 pint-Set display broken up, cant input set point
You will need to contact LG for service or a replacement. This unit is covered by a 5 year warranty. Here is the contact number for LG:
1 (800) 793-8896
May 05, 2008 | LG LD65EL Dehumidifier
Goldstar DH504EL Dehumidifier Logo
518 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
