Question about Bose 3·2·1 II System
When playing a DVD, there are red and blue lines that show up on the screen. At first I thought it was a defective DVD but put another in and it showed up again.
    President:
  • 2,047 Answers
The lines could have been caused by quite a couple of issues one could be a faulty lens from the player or the cables which are used in playing or even the screen. Try using a different screen to watch same DVD's if the problem persists then try replacing the cables for connecting to the screen and after that if it still persists then get an expert to check the lens of thee player.
Hope this solution has been helpful?
Posted on Apr 10, 2011
Blue LCD screen
I had the exact problem, mine was a YPG 535 brand new in box I put everything together with stand and FC4 pedal. When i got ready to play just a blue screen and none of the red lights came on and no sound, I notice when i was messing with the on and standby button hopeing it would work the speakers would make a popping noise I personly thought it was a manufacturing defect.....i'm sending it back to have it replace. I never had problems with yamaha products but seems like more and more defects are happing with newer portable grand series!
Feb 24, 2014 | Yamaha DGX 640 Keyboard Arranger
Bought a film (twice) as I thought the first one was defective, yet it still won't play on the blu ray machine. Can you help? All other films have been fine
If your machine plays all other blue ray discs fine, then we can rule out the machine. But if all your other discs are standard DVD movies, "meaning they not blue ray" then there is a problem with the machine. The blue ray movies require higher precision in play to show better resolution, I have encountered this many times in service. So if your machine is not the problem, the replacement disc has to be questioned.
Dec 20, 2010 | LG BD370 BLU RAY PLAYER
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
I have a trutech LMD5702RT portable duel screen dvd player the cable is broke that goes in 2nd screen we get sound but no picture. Can I buy just that cable
If its the red white and blue AV cable on both ends yes you can. If its a red white and blue AV on one end and a audio looking jack on the other end you can too. They sell all those cords at Radio shack or most electronic stores.
Jan 09, 2010 | TruTech LMD-5702RT Portable DVD Player
I have a 32" HD widescreen LCD TV/DVD combo. TDA03211c. When I put a dvd in to play it makes a noise and puts some digital garbage on the screen. Will not play dvds.
Sounds like the DVD player is defective. Just food for thought.. Try not invest in any make with a built in DVD player, they just don't last.
Oct 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Shows blueish color when i play dvd
hi..the reason to this problem is you might not
have plugged the cable properly.
check it out..
thank u..
rate me..
Apr 08, 2009 | Samsung DVD-S221 DVD Player
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
Horizontal Blue Line
WHEN YOU HAVE A SOLID BLUE LINE THAT DOES NOT MOVE...YOU HAVE A DEFECTIVE PANEL...LIVE WITH IT OR REPLACE PANEL..NOT COST EFFECTIVE TO REPLACE PANE....JOE ACE
Jun 13, 2008 | Westinghouse TX-42F430S Television
Daewoo DP42SM coloring missing blue tint on dvd playback only
I don't know are you familiar with electronic,if you are you can fix it by yourself.The problem is in video process board,the one in metal cage.What you need to do is to remove the board from the set,remove the cage, then to replace all SMD capacitors!!!And do not put SMD as replacement put the normal capacitors same values they can be fited.You should aslo replace capacitors at the PSU and check 170V,160V and 70V and adjust them after the replacement.PSU is easy part but the video board is tricky one but it can be done
Feb 15, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Screen now showing blue line at bottom
Sounds like, you have a bad optical block. Part can cost $550 to $800 + labor
Mar 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bose 3·2·1 II System Logo
60 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
